Find the max and min value from equation?
In summary, the conversation discusses finding extreme points for the function ##f(x) = 4x + y^2## on the given domain of ##-\sqrt{2} \le x \le \sqrt{2}##. It is suggested to solve for y in the equation of the ellipse and substitute this into the function to find the maximum and minimum values. The domain of the function is determined to be ##-\sqrt{2} \le x \le \sqrt{2}## and the derivative of the function is found to be ##f'(x) = 4 - 4x##. Setting this equal to zero and solving for x yields a maximum and minimum at x=1.
Helly123
581
f ' (x) = 0 --> to find extreme points
## 2x^2 + y^2 = 4##
## y = \sqrt{4 - 2x^2}##
## y ' = \frac {-2x} {\sqrt{4-2x^2}} ##
## 0 = \frac {-2x} {\sqrt{4-2x^2}} ##
x = 0
also ## 4 - 2x^2 >= 0 ##
## 4 >= 2x^2 ##
## \sqrt{2} >= x ##
## x <= +/- \sqrt{2} ##
## x= -\sqrt{2} , x = 0, x = \sqrt{2} ##
## f( -\sqrt{2} ) = 0 ## --> ##4x + y^2 = -4\sqrt{2}## --> min
## f( \sqrt{2} ) = 0 ## --> ##4x + y^2 = 4\sqrt{2}## ---> max
## f(0) = 2 ## --> ##4x + y^2 = 4##
is there something wrong?
I suppose so.
You manipulate things, but where does this ##f(x)## appear ?
Setting ##y ' = \frac {-2x} {\sqrt{4-2x^2}}=0## finds you extrema for y(x) at x = 0 (you recognize this is an ellipse ?) but that is not what you want!
## 2x^2 + y^2 = 4##
x = 0
You aren't using the fact that the points have to lie on the given ellipse.
You don't need calculus to solve this problem. In the equation of the ellipse, solve for y, and then substitute that into the expression whose max and min values you want to find. I get a maximum value of 6.
## 4 >= 2x^2 ##
## \sqrt{2} >= x ##
I get what you're trying to say, but this is not how to say it. It should be
##-\sqrt 2 \le x \le \sqrt 2##
Likes Helly123
So did I but I didn't want to spoil the fun.
And with calculus you can find maxima, minima and flexing points (is that the proper designation?), but on ##[0,1]## the function ##f(x) = x## has a lowest value of 0 and a maximum value of 1 and neither can be found with calculus !
Usual term is "inflection point".
However, noting that the derivative is constant and positive, one can conclude that the minimum occurs at the left endpoint of the interval, and the maximum occurs at the right endpoint of the same interval.
Thanks !
Back to Helly: do you now see what needs to be done (calculus or not) ?
## 2x^2 + y^2 = 4##
##\frac{x^2}{2} + \frac{y^2}{4} = 1## -> ellipse equation
y = 0
## x = \sqrt{2} \ or -\sqrt{2} ##
x = 0
## y = 2 \ or -2 ##
x = 0
## y^2 = 4 ##
## 4x + y^2 = 4 ##
y = 0
## x = 4\sqrt{2} \ or -4\sqrt{2} ##
## 4x + y^2 = 4\sqrt{2} \ or -4\sqrt{2} ##
What do you mean solve for y?
Helly123 said:
## 2x^2 + y^2 = 4##
Express y as function of x.
## y = \sqrt 4 -2x^2 ## this is y as function of x
how to solve it?
## 0 = \sqrt 4 -2x^2 ##
##4 - 2x^2 = 0##
x = -2 or 2
what am I supposed to do? using calculus?
BvU said:
Thanks !
no...
y = \sqrt 4 -2x^2
## ? You sure or is this a ##\TeX##typo and you forgot the curly brackets { } around the argument for ##\sqrt {}## ?
Good. Now you can substitute y in the function for which you want to find the maximum and the minimum value
Helly123 said:
how to solve it?
You can not solve one equation for two unknowns -- 'solve' in the sense I seem to have let you think. The sense I meant it is as Ersbeth posted (you can accept my apologies, but I think it's better if you get used to the slight ambiguity :smile:)
To help speed up things somewhat: now that you have ##y^2## as a function of ##x##, you can investigate the function ##4x+y^2## on the domain you found for ##x## -- using calculus or common sense :rolleyes:PS:
Helly123 said:
x = -2 or 2
tut tut ! What did you find in post 7 ? (the first time y=0, that is)
##2x^2 + y^2 = 4##
max and min of ## 4x + y^2? ##
Answer
## y = \sqrt{4 - 2x^2} ##
domain is
## 4 - 2x^2 >= 0 ##
so we get ## -\sqrt{2} < = x < = \sqrt{2} ##
now, question is ## 4x + y^2 ## max and min?
from equation ## 2x^2 + y^2 = 4 ## we get ## y^2 = 4 - 2x^2##
substitute ## y^2 = 4 - 2x^2 ## to ## 4x + y^2 ##
## 4x + y^2 = 4x + 4 - 2x^2 ##
## f(x) = 4x + 4 - 2x^2 ##
## f ' (x) = 4 - 4x ##
0 = 4 - 4x
x = 1 -> satisy domain
check x = 1, and x in domain for ## 4x + y^2 = 4x + 4 - 2x^2 ##
x = 1
## 4x + y^2 = 4 + 4 - 2 = 6 ##
x = ## -\sqrt{2}##
## 4x + y^2 = -4\sqrt{2} ##
x = ## \sqrt{2}##
## 4x + y^2 = 4\sqrt{2} ##
max = 6
min = ## -4\sqrt{2} ##
is the concept right? I'm lack at concept... I manipulate formula to get answer I want.
Likes BvU
oh that's substitute the y^2 to ##4x+y^2## right
Likes BvU
Yes. Well done.
One pedantic remark: you used calculus to find the maximum. As Mark said in #3, you indeed don't really need it. Can you see how ?
:smile: that's what we all do !
Likes Helly123
BvU said:
Yes. Well done.
hmm.. I get it.
##4x + 4 -2x^2##
change it to another form
##4x + 4 -2x^2 = -2(x^2 - 2x) + 4 ##
##= -2(x^2 - 2x + 1) + 2 + 4 ##
##= -2(x-1)^2 + 6 ##
so ##4x + y^2 = -2(x-1)^2 + 6 ##
max at 6, when x = 1
Likes BvU
Related to Find the max and min value from equation?
1. What is the purpose of finding the max and min value from an equation?
Finding the maximum and minimum values from an equation helps to identify the highest and lowest points on a graph, which can provide important information about the behavior of the equation. It can also help to find the optimal solution for a problem.
2. How do you find the max and min value from an equation?
To find the maximum and minimum values from an equation, you can use calculus by taking the derivative of the equation and setting it equal to 0. Then, solve for the variable to find the x-coordinate of the critical point. Finally, plug this value into the original equation to find the corresponding y-coordinate.
3. Can the max and min value from an equation be the same number?
Yes, the maximum and minimum values from an equation can be the same number, which is known as a "flat maximum" or "flat minimum". This means that the equation has a horizontal tangent line at that point, indicating that the slope (or rate of change) is 0 at that point.
4. Are there any other methods for finding the max and min value from an equation?
Yes, there are other methods for finding the maximum and minimum values from an equation, such as using a graphing calculator or graphing software to visualize the graph and identify the highest and lowest points. Additionally, for certain types of equations, you can use algebraic methods to find the maximum and minimum values.
5. Can the max and min value from an equation change?
Yes, the maximum and minimum values from an equation can change if the equation is altered in some way. For example, if the coefficients or variables in the equation are changed, it can result in a different graph and therefore different maximum and minimum values. Additionally, the maximum and minimum values can change if the equation is shifted or stretched on the graph.
