MHB Find the maximum amount of the equal annual withdrawal
  • Thread starter Thread starter Joe_1234
    Maximum
The discussion focuses on calculating the maximum equal annual withdrawal from a savings account with a principal of P25,000 at a 5% interest rate, compounded semi-annually. The recursive relationship for the account balance and withdrawals is established, leading to a closed-form solution for the balance over time. The limit condition for the account balance to approach zero is derived, resulting in the formula for the withdrawal amount. Ultimately, the maximum annual withdrawal is calculated to be approximately P1,265.63. The conclusion confirms that the closest option to this amount is P1250.
Joe_1234
P25,000 is deposited in a savings account that pays 5% interest, compounded semi-annually. Equal annual withdrawals are to be made from the account, beginning one year from now and continuing forever. The maximum amount of the equal annual withdrawal is closest to
A. P625
B. P1000
C. P1250
D. P1625
Mathematics news on Phys.org
Hello, and welcome to MHB! :)
I would let \(A_n\) be the amount in the account at the end of year \(n\), and \(W\) be the amount withdrawn at the end of year \(n\). Then we may model this problem with the following recursion:
$$A_{n+1}=1.05A_{n}-W$$
Can you give the homogeneous solution (based on the root of the characteristic equation)?
I made an error in my above post, where I used annual compounding. We want:
$$A_{n+1}=1.025^2A_{n}-W=\left(\frac{41}{40}\right)^2A_{n}-W$$
And so our homogeneous solution will take the form:
$$h_n=c_1\left(\frac{41}{40}\right)^{2n}$$
Our particular solution will take the form:
$$p_n=B$$
Substitution into the recursion yields:
$$B-\left(\frac{41}{40}\right)^2B=-W$$
$$\left(\frac{9}{40}\right)^2B=W\implies B=\left(\frac{40}{9}\right)^2W$$
And so by the principle of superposition, we obtain:
$$A_{n}=h_n+p_n=c_1\left(\frac{41}{40}\right)^{2n}+\left(\frac{40}{9}\right)^2W$$
$$A_0=c_1+\left(\frac{40}{9}\right)^2W\implies c_1=A_0-\left(\frac{40}{9}\right)^2W$$
And so our closed form is:
$$A_{n}=\left(A_0-\left(\frac{40}{9}\right)^2W\right)\left(\frac{41}{40}\right)^{2n}+\left(\frac{40}{9}\right)^2W$$
To finish the problem, we want to set:
$$\lim_{n\to\infty}A_n=0$$
In order for that to happen (for the limit to be finite), we need:
$$W=\left(\frac{9}{40}\right)^2A_0$$
Using the value \(A_0=25000\), we then find:
$$W=\frac{10125}{8}=1265.625$$
$$p_n=B$$
Tnx Sir
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
