Find the maximum KE of a charged Disc
The discussion focuses on calculating the maximum kinetic energy (KE) of a charged disc placed inside a hollow sphere. The initial potential energy of the system is derived from the potential inside the charged hollow shell, leading to the expression for potential energy as U = (σ²πR³)/(2ε₀). By applying conservation of energy and momentum, the velocities of the disc and hemisphere are related, resulting in the equation for maximum KE as KE_max = (2/5)(σ²πR³)/(ε₀). A correction is noted regarding the area of the hemisphere, which affects the mass ratio and the relationship between the velocities of the disc and hemisphere. The final calculations suggest that the maximum KE of the disc is accurately represented in the derived formula.
Hamiltonian
A thin disc of Radius R is held closing the opening of a thin hemispherical shell of the same radius. Both the bodies are made of insulating materials and have a uniform surface charge density ##\sigma## and surface mass density. When the system is released what will be the maximum KE of the disc?
##V = \frac{K q_1 q_2}{r}##, Conservation of energy&linear momentum
To find the initial potential energy of the system we can assume the disc to be placed inside a hollow sphere of the same radius and ##\sigma##, the potential energy inside a charged hollow shell is:
$$V = \frac{\sigma(4\pi R^2)}{4\pi \epsilon_0 R} = \frac{\sigma R}{\epsilon_0}$$
the potential energy of the sphere and disc system will be:
$$U = V(\sigma \pi R^2) = \frac{\sigma^2\pi R^3}{\epsilon_0}$$
##U## is the potential energy due to the disc and the sphere, but we need to find the potential energy of the disc and hemisphere system, the sphere can be assumed to be made up of two hemispheres hence each contributing to ##U/2##
therefore the initial potential energy is:
$$U_0 = \frac{\sigma^2 \pi R^3}{2\epsilon_0}$$
the disc will have maximum KE when it's at ##\infty## so the potential energy of the system ##\rightarrow 0##
(assume surface mass density of both hemisphere and disc be ##\lambda##)
hence we can conserve energy and linear momentum and solve for the maximum KE of the disc
$$\frac{\sigma^2 \pi R^3}{2\epsilon} = \frac{1}{2}(\lambda \pi R^2){v_d}^2 + \frac{1}{2}(\lambda 4\pi R^2){v_h}^2$$
$$\lambda \pi R^2 v_d = \lambda 4 \pi R^2 v_h \implies v_h = \frac{v_d}{4}$$
where ##v_h## is the velocity of the hemisphere and ##v_d## is the velocity of the disc at ##\infty##
solving the above equations gives:
$${v_d}^2 = \frac{4}{5}\frac{\sigma^2 R}{\epsilon_0 \lambda} \implies{KE}_{max} = \frac{2}{5}\frac{\sigma^2 \pi R^3}{\epsilon_0}$$
I don't have the correct answer to this question so can someone check my work and the final answer?😊
It looks like you have considered the disc and an entire spherical shell moving away from each other.
The disc’s area is ##\pi R^2## and the hemisphere’s is ##2\pi R^2## (not ##4\pi R^2##). I.e. the mass of the disc is half the mass of the hemisphere. Conservation of momentum then immediately tells you that ##v_h= \frac {v_d}{2}## in the centre-of-mass frame.
To get the split in kinetic energy you might consider using the handy relationship ##KE = \frac{p^2}{2m}## and using simple proportionality.
Likes Hamiltonian
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
