Find the maximum of E_a when the entropy is at its maximum
In summary, the maximum of the entropy occurs when N_a and N_b are both large, and E_a is the amount of energy in the system.
WeiShan Ng
36
Show that [itex]\Gamma_T[/itex] is maximum at [itex]E_a = \frac{N_aE}{N_a+N_b}[/itex]
The expression for [itex]\Gamma(E)[/itex] when [itex]N\gg 1[/itex]
[tex]\Gamma_T = C_aC_b exp \left( -\frac{E_a^2}{2N_a\mu_B^2h^2} \right) exp \left[ - \frac{(E-E_a)^2}{2N_b\mu_B^2H^2} \right][/tex]
where [itex]C_a[/itex] and [itex]C_b[/itex] are normalization constants that depends on [itex]N_a[/itex] and [itex]N_b[/itex]
In terms of the entropy:
[tex]\begin{aligned} \frac{1}{k}S_T = \frac{1}{k}(S_a+S_b) &= ln \Gamma_T \\ &= ln(C_aC_b)-\frac{1}{2(\mu_BH)^2} \left[ \frac{E_a^2}{N_a} + \frac{(E-E_a)^2}{N_b} \right]\end{aligned}[/tex]
Try to find the maximum of the entropy using the quadratic terms in the square bracket:
[tex]\begin{aligned} \frac{E_a^2}{N_a} + \frac{(E-E_a)^2}{N_b} &= \frac{(N_a+N_b)E_a^2}{N_aN_b} - \frac{2EE_a}{N_b} + \frac{E^2}{N_b} \\ &= \frac{N_a+N_b}{N_aN_b} \left[ E_a^2 - \frac{2N_aN_bEE_a}{N_b(N_a+N_b)} \right] + \frac{E^2}{N_b} \\ &= \frac{(N_a+N_b)}{N_aN_b} \left[ E_a - \frac{N_aE}{N_a+N_b} \right]^2 +\frac{E^2}{N_b} - \frac{N_a^2E^2}{(N_a+N_b)^2} \end{aligned} [/tex]
And the solution manual reduce this equation to
[tex] \frac{(N_a+N_b)}{N_aN_b} \left[ E_a - \frac{N_aE}{N_a+N_b} \right]^2 + \frac{E^2}{N_a+N_b} [/tex]
I can't get the equality of
[tex]\frac{E^2}{N_b} - \frac{N_a^2E^2}{(N_a+N_b)^2}=\frac{E^2}{N_a+N_b}[/tex]
With [tex]\frac{E^2[N_a^2+2N_aN_b+N_b^2-N_bN_a^2]}{N_b(N_a+N_b)^2}=\frac{E^2(N_a+N_b)N_b}{N_b(N_a+N_b)^2}[/tex] I just can't get both side of the equation to be equal...
Are there factors that appear both in the numerator and the denominator of your final expression? You can cancel them unless they are equal to zero.
Sorry, what I meant was I can't factor the equation [tex]N_a^2 + 2N_aN_b + N_b^2 -N_bN_a^2 [/tex] to [tex](N_a+N_b)N_b[/tex]
The error is in completing the square. The last term ##- \frac{N_a^2E^2}{(N_a+N_b)^2}## is incorrect. It should be ## - \frac{N_aE^2}{N_b(N_a+N_b)^2}##. You should check this out for yourself.
Related to Find the maximum of E_a when the entropy is at its maximum
1. What does "maximum of E_a" refer to in this context?
"Maximum of E_a" refers to the maximum energy that can be obtained from a system at a given entropy level.
2. How is the entropy of a system related to the maximum energy it can produce?
The relationship between entropy and maximum energy is described by the Second Law of Thermodynamics, which states that the entropy of a closed system will always increase over time, leading to a decrease in the available energy of the system.
3. Can the maximum energy of a system be reached without an increase in entropy?
No, the Second Law of Thermodynamics dictates that an increase in entropy is necessary in order to reach the maximum energy of a system.
4. How can the maximum of E_a be calculated or determined?
The maximum of E_a can be calculated by finding the point at which the entropy of the system is at its maximum, using mathematical equations and principles of thermodynamics.
5. Is it possible for a system to have a maximum entropy and maximum energy simultaneously?
No, the Second Law of Thermodynamics states that the maximum entropy and maximum energy of a system cannot occur at the same time, as the increase in entropy leads to a decrease in available energy.
