MHB Find the measure of angle BAC.
  • Thread starter Thread starter anemone
    Angle Measure
In triangle ABC, with D as the midpoint of AB and E as the point of trisection of BC, it is established that angle ADC equals angle BAE. A solution involves drawing a line from D parallel to AE, which leads to the conclusion that AE bisects CD. This geometric configuration reveals that angle BAC measures 90 degrees. The final calculations confirm that the angles in triangle ADC sum to 180 degrees, validating the result. The discussion highlights the importance of parallel lines and proportionality in solving the problem.
anemone
MHB
POTW Director
Hi members of the forum,
Problem:
In triangle ABC, D is the midpoint of AB and E is the point of trisection of BC nearer to C. Given that $\displaystyle \angle ADC=\angle BAE$, find $\displaystyle\angle BAC$.
I have tried to solve it using only one approach, that is by assigning $\displaystyle\theta$ and $\displaystyle\beta$ to represent the angles of CAE and ABC respectively and applied the rules of Sine and Cosine appropriately but ended up with very messy equation with many unknown values.
It's not that I didn't try it but now I feel like I've reached a plateau and I decided to ask for help at MHB.
If anyone could give me some hints, that would be great.
Thanks in advance.
Mathematics news on Phys.org
Re: Find the angle of BAC.
Problem:
https://www.physicsforums.com/attachments/630
Thanks in advance.
Let the point of trisection of $BC$ nearer to $B$ be $F$. Draw a line passing through $D$ and parallel to $AE$. Argue that this line passes through $F$. This helps you show that $AE$ bisects $CD$. Its now not very hard to figure out that $\angle BAC$ is $90$.
I see it now...the trick is to draw another line parallel to AE that starts from the point D to touch the line of BC.
I will show my full solution here as a way to express my appreciation for your help and guidance...
Join DM so that AE is parallel to DM.
It follows that $\displaystyle \frac{BD}{DA}=\frac{BM}{ME}$, i.e.
$\displaystyle 1=\frac{BM}{ME}$
$\displaystyle BM=ME$ or $\displaystyle BM=ME=EC $.
It shows that M is the point of trisection of BC nearer to B.
Similarly, by applying the proportionality theorem again, we get
$\displaystyle \frac{CN}{ND}=\frac{CE}{EM}$
$\displaystyle \frac{CN}{ND}=1$
$\displaystyle CN=ND$
This gives us also the fact that $\displaystyle CN=AN$, and $\displaystyle \angle NAC=\angle NCA=\theta $
Last, by adding up all the angles of the triangle ADC and set them equal to $\displaystyle 180^\circ$, we obtain
$\displaystyle 2\theta +2\alpha=180^\circ$
$\displaystyle \theta +\alpha=90^\circ$
$\displaystyle \angle BAC=90^\circ$
Thanks a bunch, caffeinemachine!(Smile)
https://www.physicsforums.com/attachments/631
That's great. (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
