Find the MGF of geometric,neg binomial dist.
  • Thread starter Thread starter ArcanaNoir
    Binomial
The discussion focuses on finding the moment generating functions (MGFs) for the geometric and negative binomial distributions. The geometric distribution's MGF is derived from the formula f(x)=p^x(1-p)^{x-1}, leading to the conclusion that the MGF is \frac{pe^t}{1-qe^t}. For the negative binomial distribution, which is expressed as f(x)=\frac{(x-1)!}{(x-r)!(r-1)!}p^r(1-p)^{x-r}, participants clarify the relationship between this distribution and the sum of independent geometric random variables. The conversation highlights the importance of correctly identifying the series and parameters involved in calculating the MGFs. Overall, the thread emphasizes the mathematical derivation and verification of these functions.
ArcanaNoir
Find the MGF (Moment generating function) of the
a. geometric distribution
b. negative binomial distribution
geometric distribution: f(x)=p^x(1-p)^{x-1} where x=1,2,3...
negative binomial distribution: f(x)= \frac{(x-1)!}{(x-r)!(r-1)!}p^r(1-p)^{x-r} where x=r, r+1, r+2...
MGF= E(e^{tx})
a. \sum_{x=1}^{\infty}e^{tx}p^x(1-p)^{x-1}
let q=1-p
\sum_{x=1}^{\infty}e^{tx}p^xq^{x-1}
\sum_{x=0}^{\infty}(pe^t)q^x
=\frac{pe^t}{1-q}
that's as close as I can get to approximating the solution,
but the book says the answer is \frac{pe^t}{1-qe^t}
b. \sum_{x=r}^{\infty}\frac{(x-1)!}{(x-r)!(r-1)!}e^{tx}p^rq^{x-r} where q=1-p
Those aren't the distributions I'm used to. Are you sure these formula's are correct??
For the geometric distribution, I got
f(x)=p^x(1-p)
and the negative binomial is
f(x)=\binom{x+r-1}{x}(1-p)^rp^x
Could you recheck this first?
oh good god. I was looking at point binomial.
so here's what I get now,
\sum_{x=1}^{\infty}e^{tx}p(1-p)^{x-1} letting q= (1-p)
= \frac{p}{q} \sum_{x=1}^{\infty}e^{tx}q^{x}
= \frac{p}{q} \sum_{x=1}^{\infty}(e^{t}q)^x
Yes, go on... You have a geometric series right now.
the negative binomial I have as being : \binom{x-1}{r-1} p^r(1-p)^{x-r}
which I figured equals : \frac{(x-1)!}{(x-1-(r-1))!(r-1)!}p^r(1-p)^{x-r}
so, \frac{1}{1-r} ?
( \frac{p}{q} ) \frac{1}{1-e^{t}q} ?
ArcanaNoir said:
so, \frac{1}{1-r} ?
That's the sum of the geometrci series when you start summing from 0. But you start summing from 1 here.
but if I sum from zero, won't I have \frac{p}{q} \sum_{x=0}^{\infty}(e^{t}q)^{x+1} oh wait. I see. hold on
nevermind. I don't see. am I suppose to have x-1 at x=0 to do the sum?
oop, there it is! found the answer to the geometric. thanks for the support on that.
MGF= E(e^{tx})
let q=1-p
=\frac{pe^t}{1-q}
The negative binomial with parameters p and r is the distribution of a sum of r independent geometric random variables with parameter p. What do you know about the MGF of a sum of independent random variables?
RGV
9K
