Find the min/max r of particle with a central force
In summary, a force field of magnitude −kr(rˆ) acting on a particle of mass m in a non-circular orbit results in a decrease in its angular momentum and energy.
Luke Cohen
30
A force field in 2-d F~ = −kr(rˆ) with U(r) = k(r^2)/2 acts on a particle of mass m.
The particle is now in a non-circular orbit. In terms of the particle’s angular momentum L and energy E,
d) What is its closest approach to the origin? e) What is its furthest distance from the origin?
I am confused on how to start this problem. I can't switch my variable so that I get an equation for phi... Can someone help me out starting this off?
Thanks!
E = T + U
T = L^2/(2r^2) b/c dr/dt = 0
U = Kr^2/2
I tried to do the above and solve the r^4 + ...r^2 + ... = 0 quadratic, but I can't. Can someone please help me?
Luke Cohen said:
F~ = −kr(rˆ)
What does this mean? It looks like you're trying to write the formula for the force, but this collection of symbols makes no sense.
Luke Cohen said:
dr/dt = 0
THis contradicts the statement that the orbit is non-circular.
For the first part, it's an r hat. And dang, you're right about the second part. I am going to change that. How should I go from there?
Do you mean quartic?
Write out in full the equation that needs to be solved. If you've derived the equation correctly, it should be easy to see how to solve it once it's written down.
I don't think I did, as I was going under the assumption that dr/dt = 0, which I can see now only applies for circular motion. Is there a particular direction you think I should tackle this problem from? It says I need to answer in terms of E and L, and I am really stuck on how that is possible.
It is not true in general that dr/dt=0, but there may be points in the orbit where that condition momentarily holds. What points would they be and what energy equation can you write that applies at such a point?
ah, okay so my quartic equation was correct.
I said E = L^2/(2mr^2) + kr^2/2 giving me a quartic equation of r^4 - 2Er^2/k + L^2/(mk) = 0
Can you think of a way of converting it into a quadratic?
I had been working on that for a while and couldn't figure anything out. Can you point me in the right direciton?
Try substitution - in the same meaning of 'substitution' as applies in integration by substitution. We are not integrating here. But the same trick may work.
substituting what though? the only common term is 1/k, but that wouldn't help
In integration by substitution you substitute a new variable, call it u, for some function of the variable you are trying to integrate over.
So here, try substituting a new variable for some function of the variable you are trying to solve for.
Okay, so I get u^2 - 2Eu/k + L^2/mk = 0 using the substitution u = r^2.
After that, I use the quadratic formula, then square my answer to get r. That would give me my Rmin and Rmax? Is the physics I performed correct in the above equation? Thanks for the help thus far.
Square root, not square.
The physics is fine. It's just the conservation of energy and angular momentum.
A physical system that would act like this would be a heavy ball attached to a fixed metal rod by a spring that can rotate around the rod.
Likes Luke Cohen
Awesome. you are a huge help. Thanks so much!
Related to Find the min/max r of particle with a central force
1. What is a central force?
A central force is a type of force that acts on a particle and is always directed towards or away from a fixed point in space, known as the center. Examples of central forces include gravity and electrostatic forces.
2. How is the minimum/maximum r of a particle with central force calculated?
The minimum (rmin) and maximum (rmax) values of a particle with central force are calculated using the equation r = 1/(μ*|L|2), where μ is the reduced mass of the particle and L is its angular momentum.
3. What is the significance of finding the minimum/maximum r of a particle with central force?
The minimum/maximum r of a particle with central force can help determine the stability and trajectory of the particle. A smaller r indicates a stronger force towards the center, while a larger r indicates a weaker force and potentially a more elliptical orbit.
4. Can the minimum/maximum r of a particle with central force change?
Yes, the minimum/maximum r can change if there is a change in the magnitude or direction of the central force acting on the particle. This can result in a change in the particle's orbit or trajectory.
5. How is the concept of minimum/maximum r with central force related to Kepler's laws of planetary motion?
Kepler's laws of planetary motion describe the motion of planets around the sun, which can be considered as a central force acting on the planets. The concept of minimum/maximum r with central force is related to Kepler's laws as it helps explain the shape and stability of planetary orbits.
