MHB Find the Min Sum of $m$ and $n$ for $(4^m+4^n)\ mod\ 100=0$
  • Thread starter Thread starter Albert1
    Sum
The discussion focuses on finding the minimum sum of integers m and n such that (4^m + 4^n) mod 100 equals 0, with m greater than n. It establishes that for the equation to hold, 4^(m-n) must equal -1 mod 25. The powers of 4 are examined, revealing that 4^5 is congruent to -1 mod 25. Consequently, it is determined that 4^6 + 4^1 equals 0 mod 100, leading to the conclusion that the minimum value of m+n is 7. The solution is confirmed as correct.
Albert1
if $(4^m+4^n)$ mod 100=0
(here $m,n\in N \,\, and \,\,m>n$)
please find:$min(m+n)$
Mathematics news on Phys.org
[sp]$4^m+4^n = 4^n(4^{m-n}+1)$. If $4^{m-n} = -1\pmod{25}$ then $4^n(4^{m-n}+1) = 0 \pmod{100}.$ The first few powers of $4$ are
$4$
$16$
$64$
$256$
$1024 = 4^5$.​
Since $4^5 = 24 = -1\pmod{25}$, it follows that $4^6 + 4^1 = 0\pmod{100}$ (and in fact $4^6+4^1 = 4096 + 4 = 4100$). So the minimum value of $m+n$ is $6+1=7.$[/sp]
$4$
$16$
$64$
$256$
$1024 = 4^5$.​
very good , the answer is correct !
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
