Find the minimum distance between the curves
In summary: Which yieldsd = \sqrt{\left(x_2 - {y_1}^2-1\right)^2 + \left({x_2}^2-y_1 +1\right)^2}So the distance between these points isd = \sqrt{(x_2-y_1)+1}
utsav55
Find the minimum distance between the curves (Parabola) y^2 = x-1 and x^2 = y-1
y^2 = x-1
x^2 = y-1
Tried to find the distance between their vertex, but the answer was wrong and no where near.
Welcome to Physics Forums.
y^2 = x-1
x^2 = y-1
In general, what is the distance between two points?
Well, we can use the distance formula to find the distance between 2 points, but in this question between which 2 points we need to find the distance and why?
The distance formula is used to compute the distance between two sets of points, say (x1, y1) and (x2, y2). In general, these can be any two points. However, in this case we know that these points must lie on two curves. So we can replace one co-ordinate in each case with an expression in terms of the remaining co-ordinate.
Do you follow?
Do you follow?
Just didn't got the last sentence.
Instead of finding the distance between the two points (x1,y1) and (x2,y2) you want to find the distance between, say,
[tex]\left({y_1}^2+1,y_1\right)\text{ and } \left(x_2, {x_2}^2+1\right)[/tex]
Does that make sense?
Please explain me that how you arrived at that conclusion, sorry I didn't got that...
Okay let us take a point (x1, y1) on the curve y2 = x-1, and another point, (x2, y2) on the curve x2 = y-1. Now, suppose that these two points represent the closest points on the two curves. We want to find the distance between them. Currently, we have four variables: x1, x2, y1 and y2; but we can reduce the number of variables. Since we know that the points must lie on their respective curves we can simply substitute one co-ordinate into the equation of the curve. For example, let us take the first point: (x1, y1). We know that since this point lies on the first curve it must satisfy the equation y2 = x-1. In other words, y12 = x1-1. Hence, x1 = y12+1. Therefore we can re-write the point (x1, y 1) in terms of y1 only: (y12+1, y1).
Do you now follow?
Do you now follow?
Yes, got till here.
How to proceed from here please? We got 2 points, 1 lying on 1 curve. How do we find the distance now?
The answer is a numeric value...
utsav55 said:
Yes, got till here.
The next step would be to repeat the above steps for the second point, yielding the second expression I stated in my previous post. Then, we have the distance formula
[tex]d = \sqrt{\left(x_2 - x_1\right)^2 - \left(y_2-y_1\right)^2}[/tex]
Now, we substitute in our two points,
[tex]d = \sqrt{\left(x_2 - {y_1}^2-1\right)^2 - \left({x_2}^2-y_1 +1 \right)^2}[/tex]
So, you want to find the minimum distance between the two curves.
What do you think out next step would be?
Use maxima/minima concept??
Indeed. So you want to minimise d(x2, y1) with respect to x2 and y1. It would be useful to note that,
[tex]d\left(x_2,y_1\right) = \sqrt{f\left(x_2,y_1\right)}[/tex]
Hence, one could simply minimise f in order to find the minimum of d.
FAQ: Find the minimum distance between the curves
What is the definition of minimum distance between two curves?
The minimum distance between two curves is the shortest distance between any two points on the two curves.
How is the minimum distance between curves calculated?
The minimum distance between curves is calculated by finding the perpendicular distance between any two points on the two curves. This can be done using calculus and the distance formula.
Can the minimum distance between curves be negative?
No, the minimum distance between curves is always a positive value. It represents the shortest distance between the two curves and cannot be negative.
What if the two curves do not intersect?
If the two curves do not intersect, then the minimum distance between them will be the distance between the two closest points on the curves. This can be calculated by finding the shortest distance between any point on one curve and any point on the other curve.
Can the minimum distance between curves be greater than zero?
Yes, if the two curves overlap or if one curve completely encompasses the other, the minimum distance between them will be zero. However, if the two curves do not overlap at all, the minimum distance between them will be greater than zero.
