Find the minimum of (4xyz)/(3)+x²+y²+z²
  • MHB
  • Thread starter anemone
  • Tags
    Minimum
In summary, the purpose of finding the minimum of (4xyz)/(3)+x²+y²+z² is to determine the lowest possible value that can be obtained by varying the values of x, y, and z. To find the minimum, the partial derivatives with respect to each variable must be taken and set equal to 0, and the resulting system of equations can be solved to find the values of x, y, and z that minimize the equation. The coefficient of (4xyz)/(3) affects the overall value of the equation, and the minimum can be negative if the values of x, y, and z are chosen in a way that results in a negative value for (4xyz)/(3). This concept can be applied
anemone
MHB
POTW Director
3,883
115
Let $x,\,y,\,z$ be the lengths of the sides of a triangle such that $x+y+z=3$.
Find the minimum of $\dfrac{4xyz}{3}+x^2+y^2+z^2$.
Mathematics news on Phys.org
My solution:
We see that there is cyclic symmetry in the objective function $f$ and constraint $g$, thus the critical point is:
\(\displaystyle (x,y,z)=(1,1,1)\)
We then find:
\(\displaystyle f(1,1,1)=\frac{13}{3}\)
Testing another point:
\(\displaystyle f\left(\frac{1}{2},\frac{1}{2},2\right)>\frac{13}{3}\)
Hence:
\(\displaystyle f_{\min}=\frac{13}{3}\)
MarkFL said:
My solution:
We then find:
Hence:
Very well done, MarkFL! (Sun) And thanks for participating!
FAQ: Find the minimum of (4xyz)/(3)+x²+y²+z²
What is the purpose of finding the minimum of (4xyz)/(3)+x²+y²+z²?
The purpose of finding the minimum of this equation is to determine the lowest possible value that can be obtained by varying the values of x, y, and z. This information is useful in mathematical optimization problems and can help in finding the most efficient solutions.
How do you find the minimum of (4xyz)/(3)+x²+y²+z²?
To find the minimum of this equation, we need to take the partial derivatives with respect to each variable (x, y, and z) and set them equal to 0. Then, we can solve the resulting system of equations to find the values of x, y, and z that minimize the equation.
What is the significance of (4xyz)/(3) in the equation?
The coefficient of (4xyz)/(3) affects the overall value of the equation, as it is multiplied by the product of x, y, and z. This means that the value of (4xyz)/(3) will increase or decrease the overall value of the equation, depending on the values of x, y, and z.
Can the minimum of (4xyz)/(3)+x²+y²+z² be negative?
Yes, it is possible for the minimum of this equation to be negative. This would occur if the values of x, y, and z are chosen in a way that minimizes the equation while still resulting in a negative value for (4xyz)/(3).
How can finding the minimum of (4xyz)/(3)+x²+y²+z² be applied in real-life situations?
Finding the minimum of this equation can be applied in various real-life situations, such as in engineering, economics, and physics. For example, it can be used to optimize the design of structures by minimizing the amount of material used, or to find the most cost-effective solution for a business problem.
