Find the missing digits in the calculations below
  • Thread starter Thread starter Math100
    Calculations
The discussion focuses on finding the missing digit, denoted as χ, in the calculation 51840·273581=1418243χ040 using modular arithmetic. It establishes that χ must satisfy conditions for both modulo 9 and modulo 11. For modulo 9, it concludes that χ can be either 0 or 9, while for modulo 11, it determines that χ must be 9. The final result confirms that χ=9 is the only solution that meets both conditions. The discussion highlights the importance of understanding divisibility rules for 9 and 11 in solving such problems.
Math100
Working modulo ## 9 ## or ## 11 ##, find the missing digits in the calculations below:
## 51840\cdot 273581=1418243\chi 040 ##.
None.
First, consider modulo ## 9 ##.
Then ## 9\mid (5+1+8+4+0)\implies 9\mid 18\implies 9\mid 51840 ##.
Since ## 51840\cdot 273581=1418243\chi 040 ##, it follows that ## 9\mid 1418243\chi 040 ##.
This means ## 9\mid (1+4+1+8+2+4+3+\chi+0+4+0)\implies 9\mid (27+\chi)\implies 9\mid\chi ##.
Thus ## \chi=0 ## or ## \chi=9 ##.
Next, consider modulo ## 11 ##.
Then ## 11\mid (1-8+5-3+7-2)\implies 11\mid 0\implies 11\mid 273581 ##.
Since ## 51840\cdot 273581=1418243\chi 040 ##, it follows that ## 11\mid 1418243\chi 040 ##.
This means ## 11\mid (0-4+0-\chi+3-4+2-8+1-4+1)\implies 11\mid (-13-\chi)\implies 11\mid (13+\chi) ##.
Thus ## \chi=9 ##.
Therefore, ## \chi=9 ##.
Likes fresh_42 and Delta2
Math100 said:
Homework Statement:: Working modulo ## 9 ## or ## 11 ##, find the missing digits in the calculations below:
Relevant Equations:: None.
Thus ## \chi=9 ##.
Looks good.
Likes Math100 and Delta2
Hmm so it seems to me you use two lemmas that would be good if you had explicitly mentioned them:
  1. 9 divides a number if and only if it divides the sum of its digits in base 10
  2. 11 divides a number if and only if it divides the alternating sum and difference of its digits in base 10
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
