Find the moment of inertia about the x axis
The discussion focuses on calculating the moment of inertia about the x-axis for a system of particles connected by rigid rods. The formula I = sum of (r^2 * m) is used, but confusion arises regarding the use of negative distances from the axis of rotation. A participant initially miscalculates the moment of inertia, arriving at 140 instead of the correct value of 92. The conversation also touches on finding the total kinetic energy using the formula (sum of) mi vi^2/2. Clarification on these calculations is sought to resolve the issues faced.
integra2k20
Rigid rods of negligible mass lying along the y-axis connect three particles (Fig. P10.20). The system rotates about the x-axis with an angular speed of 2.90 rad/s.
Figure P10.20
(a) Find the moment of inertia about the x axis.
______kgm2
Find the total rotational kinetic energy evaluated from 1/2 I2.
______J
(b) Find the tangential speed of each particle.
______m/s (4.00 kg particle)
______m/s (2.00 kg particle)
______m/s (3.00 kg particle)
Find the total kinetic energy evaluated from mi vi2/2.
______J
I = sum of (r^2*m)
My teacher told us to use I = sum of (r^2 * m) i am not sure how this works if some of the r's (distances from the axis of rotation) are negative. i tried subtracting the negative ones, or just plugging them in and squaring them, thus making them positive, to no avail. Any help would be greatly appreciated! the most difficult part of this for me is the moment of inertia.
What are you struggling with?
finding the moment of inertia of the structure, after that i think i should be able to handle it
So you've done something like this;
I = 4(3)^2 + 2(-2)^2 + 3(-4)^2
Is that correct?
Is that correct?
yup, i did exactly that...didn't get it right...
oh wow, never mind, i made some type of calculation mistake. for some reason i got 140 when it shoudl have been 92. my last question is about the last part, it says to find the total kinetic energy evaluated from (sum of)mi vi^2/2.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
