Find the net electric field at the center of the foil
In summary, a large, thin plastic disk with radius 1.1 meter carries a uniformly distributed charge of -7e-5 C. A circular aluminum foil with radius 6 cm and thickness 1 millimeter is placed 3 mm from the disk. The net electric field at the center of the foil can be found by considering the field from the charged disk and the induced charge on the inner surface of the foil. To calculate the magnitude of the charge on the inner surface of the foil, a Gaussian surface can be used such that one end passes through the middle of the foil and the other end passes through the charged disk, allowing for the relation of flux to the charge enclosed by the surface.
Lee33
160
A large, thin plastic disk with radius R = 1.1 meter carries a uniformly distributed charge of Q = -7e–5 C. A circular piece of aluminum foil is placed d = 3 mm from the disk, parallel to the disk. The foil has a radius of r = 6 cm and a thickness t = 1 millimeter.
a. Find the net electric field at the center of the foil.
b. Calculate the magnitude q of the charge on the left circular face of the foil.
2. The attempt at a solution
How can I solve this problem? If I have a disk uniformly charged then I know how to calculate the electric field from an observation location but I don't know how to calculate the electric field when there is a foiled disk next to the plastic disk.
This looks like Gauss' Law.
For a it's asking for the electric field inside the foil, and what do you know about the field inside of an isolated conductor?
For b try putting a Gaussian surface into the problem (let's say a cylinder) such that one end passes through the middle of the foil and the other end passes through the charged disk to the other side. Then you can relate the flux through that surface to the charge enclosed by it, which will be charge of the disk that lies inside the cylinder, and the charge on the inner surface of the foil.
I can't use Gauss law. We haven't been taught that yet.
Related to Find the net electric field at the center of the foil
1. What is the net electric field at the center of the foil?
The net electric field at the center of the foil is the vector sum of all the individual electric fields created by the charges on the foil. It is a measure of the overall strength and direction of the electric field at that point.
2. How do you calculate the net electric field at the center of the foil?
To calculate the net electric field at the center of the foil, you will need to know the magnitude and direction of each individual electric field created by the charges on the foil. Then, you can use the principle of superposition to add up all the electric fields and determine the net electric field at the center.
3. What factors affect the net electric field at the center of the foil?
The net electric field at the center of the foil is affected by the magnitude and location of the charges on the foil, as well as the distance between the charges and the center of the foil. Additionally, the presence of other external charges or conductors nearby can also influence the net electric field at the center of the foil.
4. Why is it important to find the net electric field at the center of the foil?
Knowing the net electric field at the center of the foil is important for understanding the behavior of charged objects and how they interact with each other. It can also be useful in practical applications such as designing electrical circuits or studying the behavior of charged particles in a vacuum.
5. Can the net electric field at the center of the foil be zero?
Yes, it is possible for the net electric field at the center of the foil to be zero. This can happen if the individual electric fields created by the charges on the foil cancel each other out due to their magnitudes and directions. In this case, the net electric field at the center would be considered to be neutral, meaning there is no overall electric field present.
