MHB Find the number of positive integer values
  • Thread starter Thread starter anemone
    Integer Positive
The discussion revolves around finding the number of positive integer values of n for which the quadratic equation 2x^2 + 689x + n = 0 has an integer solution. The key insight is that n can be expressed as n = -2k^2 - 689k, where k is an integer. By analyzing the conditions for n to be positive, it is determined that k must be in the range -344 ≤ k ≤ -1, resulting in 344 valid integer values for n. The participants confirm this conclusion through various approaches, reinforcing the solution's validity. Thus, the total number of positive integer values of n is 344.
anemone
MHB
POTW Director
Hi MHB,
This problem drives me crazy because first, I have not encountered a problem like this before (but this is only an excuse and it must be my incompetence that holds me back from cracking it successfully) and I called off the attempt because I don't think I can solve it.
Problem:
For how many positive integer values of n does the equation $2x^2+689x+n=0$ have an integer solution?
Attempt:
roots$=\dfrac{-689 \pm \sqrt{689^2-8n}}{4}=\dfrac{-689 \pm k}{4}$ where $k=\sqrt{689^2-8n}$ hence
roots$=-172.25+0.25k, -172.25-0.25k$
roots$=-172.25+m-0.25, -172.25-(m-0.25)$ where $m-0.25=0.25k$
roots$=-172.5+m, -172-m$
In order for the original given quadratic equation to have only one integer solution, we see that $m$ must be an integer.
If we work on the product of the roots, we see that
$(-172.5+m)(-172-m)=\dfrac{n}{2}$
which simplifies to
$59340+m-2m^2=n$
Okay, if I let $m=150$ I then get $n=14490$ but I don't believe I have to try out all the possible values of $m$ for this problem.
And I don't know what else I can do to determine the number of positive integers $n$ that the problem asks right from where I stopped.
Any help/advice would be greatly appreciated. Thanks!
Mathematics news on Phys.org
Hint: Try using:
$$n=-2k^2-689k$$ where $$k\in\mathbb{Z}$$.
Can you show then that one of the roots must be $x=k$?
And then solve $$n>0$$ to see how many integers you get.
MarkFL said:
Hint: Try using:
Hi MarkFL,
Thanks for helping me out again!
Now everything makes perfect sense to me...the problem told us $n$ is positive integer, and we could rewrite the given quadratic equation to make $n$ the subject and then set its equivalent greater than zero...
So from
$$n=-2k^2-689k$$ where $$k\in\mathbb{Z}$$,
we have
$$n=k(-2k-689)$$
and since the quadratic equation has only one integer root, then $x=k$ must be right and now, if we set $n>0$, we need to consider for two cases. First case deals with the case where $k<0$ and second be the case where $k>0$.
If $k<0$, in order for $n>0$, we see that we must set $-2k-689<0$ or $k>-344.5$.
The number of positive $n$ values that we can get here is hence 344.
The second case gives us zero solution. Therefore, the total number of positive integer values of $n$ such that the equation $2x^2+689x+n=0$ have an integer solution is 344.
Thank you Mark for your help!
Yes, I get the same number of values. I found with the value for $n$ I suggested, we get:
$$f(x)=(x-k)\left(2(x+k)+689 \right)=0$$
The first factor gives us the integral root:
$$x=k$$
While the second root is:
$$x=-\left(k+\frac{689}{2} \right)$$
which cannot be an integer for any value of $k$.
In order for $n$ to be a positive integer, we require:
$$2k^2+689k<0$$
$$k(2k+689)<0$$
Thus:
$$-344\le k\le-1$$
And, as you found, there are 344 values $n$ may have to satisfies the given requirements.
solution by MARKFL and anemone both good
here is another
let (2x+ a)(x+b) = 2x^2+689x+n
as n is +ve both a and b positive or -ve,
a is odd else 2 integer solutionsor 2x^2 + (a + 2b) = 2x^2+689x+n
a and b cannot - ve as sum is positive
0 < 2b < 689 and hence 0 < b < 344.5
so there are 344 values of b and also n
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
