Find the number of real numbers that satisfy the given equation
In summary, the conversation involved finding the number of real solutions for the equation $\sin x = \frac{x}{100}$. The correct answer was determined to be 63, and the participants acknowledged a mistake made in the initial solution. The conversation ended with a positive exchange and appreciation for the opportunity to learn.
anemone
MHB
POTW Director
3,883
115
How many real numbers $x$ satisfy $\sin x=\dfrac{x}{100}$?
Mathematics news on Phys.org
first let us look at positive x and same number of solutions shall be for -ve x
as $\sin,x$ and $x$ both are odd functions.
as $\sin\,x$ is less than 1 so x shall be less than 100 and so if we draw a sin curve there shall be $\dfrac{100}{2\pi}$ or 15.91 ( around 16) units so there shall be 16 parts( 1/2 oscilaltions) in positive side and 16 in -ve side.
for each on the curve y = x shall intersect the sin curve 2 times so 16 in positive side including zero) so there is 1 value at 0, 15 positive values and 15 -ve values or 31 values
$-100\lt x\lt100$. The positive peaks of $\sin(x)$, between 0 and 100, are at $\frac{(4k+1)\pi}{2},\;k\in\mathbb{Z},\,0\le k\le15$. Since the zero of $\sin(x)$ immediately following $\frac{61\pi}{2}$ is at $31\pi$ and $31\pi\lt100$, we count 16 peaks and 32 intersections of $\sin(x)$ and $\frac{x}{100}$. By symmetry, there are 32 intersections on the interval $-100\lt x\lt0$, so we count 64 intersections. Adding 1 for the intersection at $x=0$ gives a total of 65 intersections, so there are 65 real numbers for which $\sin(x)=\frac{x}{100}$$$\text{ }$$
Hi kaliprasad and greg1313,
Thank you for participating in this challenge but the correct answer should be 63...(Nod)
Thanks anemone,
I realize my mistake. I am not making an excuse but it was a counting mistake.
in 16 intervals x cuts it 2times one for sin x going from 0 to 1 and another for going down from 1 to 0 so 2 times and 16 intervals give 32 ( including a zero) so 31 positive values and 31 -ve values and one zero so 63
Thanks.$$\text{ }$$
I should have checked the intersection points around 0. 65 - 2 = 63.
kaliprasad said:
Thanks anemone,
You're welcome, Kali! You know, even if you made some other blunders but not the counting error, I would still give you multiple chances to fix your solution because you are not only a great friend to me and to MHB, you are one of the very great and precious challenge problem solvers too!:)
greg1313 said:
Thanks.$$\text{ }$$
You're welcome, greg1313! I am so glad that I have now another member who likes to participate in my challenge problems, thanks!
Thank you for presenting an opportunity to learn. :)
FAQ: Find the number of real numbers that satisfy the given equation
How do I find the number of real numbers that satisfy a given equation?
To find the number of real numbers that satisfy an equation, you can use algebraic techniques such as substitution or elimination. You can also graph the equation to visually determine the number of solutions.
What is the difference between real and imaginary numbers?
Real numbers are numbers that can be represented on a number line and include all rational and irrational numbers. Imaginary numbers involve the square root of a negative number and are typically written as a multiple of the imaginary unit, i.
Can an equation have an infinite number of real solutions?
Yes, an equation can have an infinite number of real solutions. This is often the case for equations with variables raised to an even power, such as x^2 = 4, which has two real solutions, x = 2 and x = -2.
How do I know if an equation has no real solutions?
An equation has no real solutions if the discriminant (b^2-4ac) is negative, meaning that the equation has only imaginary solutions. Additionally, if the equation is a contradiction, such as 0 = 1, then there are no real solutions.
Are there any shortcuts or tricks for finding the number of real solutions to an equation?
There are some shortcuts or rules of thumb that can help determine the number of real solutions to an equation. For example, a polynomial equation with degree n will have at most n solutions. Also, the number of sign changes in the coefficients of a polynomial can give an estimate of the number of positive and negative real solutions. However, these methods may not always be accurate, and it is best to use algebraic techniques to find the exact number of real solutions.
