Find the number of real solutions
  • MHB
  • Thread starter anemone
In summary, the number of real solutions to an equation can be determined by analyzing the degree of the equation and the number of distinct roots. Real solutions are values of the variable that satisfy the given equation and are represented by real numbers, while imaginary solutions are values that do not satisfy the equation and are represented by imaginary numbers. An equation can have more than one real solution, and to solve for these solutions, various methods such as factoring or using the quadratic formula can be used. If an equation has no real solutions, it means that there are no values of the variable that satisfy the given equation, and it is important to note that an equation can still have complex solutions which are a combination of real and imaginary numbers.
anemone
MHB
POTW Director
3,883
115
How many real solutions does the following system have?
$x+y=2$
$xy-z^2=1$
Mathematics news on Phys.org
Here is my solution:
Given $x+y = 2$ and $xy-z^2 = 1\Rightarrow xy = 1+z^2 \geq 1$
So $xy\geq 1$ Means either both$x,y$ are positive quantity OR both $x,y$ are negative quantity
But Given $x+y = 2$. So $x,y>0$
Now Using $\bf{A.M\geq G.M}$, we get $\displaystyle \frac{x+y}{2}\geq \sqrt{xy}$
So $xy\leq 1$ and equality hold when $x = y= 1$ but above we have got $xy\geq 1$
So $xy = 1$ means $x=y =1$. So $z=0$
So there is only one solution which is given as $(x,y,z) = (1,1,0)$
Thanks for participating, jacks!
And thanks also for showing us a nice method to solve the problem!:)
[sp]Substitute $y = 2-x$ in the second equation: $x(2-x) - z^2 = 1$. Then $-(x-1)^2 - z^2 = 1-1 = 0$, or $(x-1)^2 + z^2 = 0$. So the only solution is $(x,y,z) = (1,1,0).$[/sp]
x = 1 - p, y = 1 + p give
xy - z^2 = 1
or 1-p^2 - z^2 = 1 or p^2 + z^ 2 = 0
p = 0 and z = 0 -> x =y = 1 , z = 0
so only one solution
FAQ: Find the number of real solutions
How do you determine the number of real solutions to an equation?
The number of real solutions to an equation can be determined by analyzing the degree of the equation and the number of distinct roots. The degree of the equation is the highest power of the variable present in the equation. For example, a quadratic equation with a degree of 2 can have a maximum of 2 real solutions. The number of distinct roots can be found by solving the equation and counting the number of unique solutions.
What is the difference between real and imaginary solutions?
Real solutions are values of the variable that satisfy the given equation and are represented by real numbers. These solutions can be plotted on a number line and have a corresponding point on the graph. On the other hand, imaginary solutions are values of the variable that do not satisfy the equation and are represented by imaginary numbers. These solutions cannot be plotted on a number line and do not have a corresponding point on the graph.
Can an equation have more than one real solution?
Yes, an equation can have more than one real solution. For example, a quadratic equation with a degree of 2 can have a maximum of 2 real solutions. This means that there can be 0, 1, or 2 real solutions depending on the coefficients of the equation.
How do you solve an equation to find the real solutions?
To solve an equation and find the real solutions, you can use various methods such as factoring, completing the square, or using the quadratic formula. These methods involve manipulating the equation to isolate the variable and then solving for its value. It is important to check the solutions obtained to ensure they are valid and satisfy the original equation.
What does it mean if an equation has no real solutions?
If an equation has no real solutions, it means that there are no values of the variable that satisfy the given equation. This can happen when the equation has a degree higher than 2 or when the solutions are imaginary. It is important to note that an equation can still have complex solutions, which are a combination of real and imaginary numbers.
