MHB Find the only value of N which satisfies all of the following
  • Thread starter Thread starter lmae
    Value
The discussion revolves around finding a natural number N that meets several specific criteria: it must be between 10 and 20, even, a multiple of 5, and have an irrational square root. The potential candidates are narrowed down to 12 and 20 based on the conditions of being even and having an integer result when divided by 4. However, only 20 meets all the criteria, as its square root is irrational. Participants emphasize the importance of understanding the question and the mathematical terms involved. The final conclusion is that the only value of N that satisfies all conditions is 20.
lmae
With full working, find the only value of N which satisfies ALL of the following conditions.
N is a natural number
10<N less than or equal to 20
N is even
N/4 is an integer
Square root of N is an irrational number
N is a multiple of 5
Does anyone understand this question and could work it out for me please?
Mathematics news on Phys.org
N is even
N/4 is an integer
Hi, lmae!
There are not many natural numbers between 10 and 20. They are 11, 12, 13, 14, 15, 16, 17, 18, 19 and 20. For each of those numbers, verify the other conditions. For example, is 11 even? Is 12/4 an integer?
Also please read the forum http://mathhelpboards.com/rules/, especially rule #11. (Click on the "Expand" button on top.) Please describe what exactly help you need. Saying "I don't understand this question" is not informative. Saying "I don't know what irrational numbers are" is much better.
Hi lmae. The following was posted in the duplicate thread you posted in calculus (which I have since deleted):
Evgeny.Makarov said:
If you need to ask the moderators to move a post, click on the black triangle with an exclamation mark on the left under the post and describe what needs to be done. I have done it for you in this instance.
Please try to avoid posting duplicates. If you have problems follow the above advice and we'll take care of it. Thanks guys. :)
Do you understand what the words used here mean?
so 1, 2, 3, 4, 5, 6, ...
So, 11, 12, 13, 14, 15, 16, 17, 18, 19, or 20
N is even
So 12, 14, 16, 18, or 20
N/4 is an integer
12/4= 3, 14/4= 3 and 1/2, 16/4= 4, 18/4= 4 and 1/2, 20/4= 5
so 12, 16, or 20
square root of 12= 2 times square root of 3 so irrational. square root of 16= 4. square root of 20= 2 times square root of 5 so irrational.
So 12 or 20.
12= 2*2*3, 20= 2*2*5.
Hi.
I understood each of the different parts but didn't understand what the question was asking of me as a whole, hence the way I worded the question. And I apologise for double posting my question, I did edit it to say I posted in wrong thread and wasn't sure how to delete. Thanks for the help.
I think it is pretty clear: "Find the only value of N which satisfies ALL of the following conditions". I hope you understand the question now.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
