Find the orthogonal trajectories
In summary, orthogonal trajectories are a set of curves that intersect another set of curves at right angles and have various applications in fields such as engineering and physics. To find them, you need to determine the gradient of the original curves and use the fact that the product of the gradients of two orthogonal curves is -1. They can only be found for certain types of curves and are important in the design of structures to ensure stability and efficiency.
manal950
177
Hi all
376730650.jpe
Start all over again! Each "[itex]\lambda[/itex]" gives a different member of the family of curves. To have an equation that describes the family and not an individual member, you have to elimininate [itex]\lambda[/itex]. That's the whole point of differentiating.
Related to Find the orthogonal trajectories
1. What are orthogonal trajectories?
Orthogonal trajectories are a set of curves that intersect another set of curves at right angles.
2. Why do we need to find orthogonal trajectories?
Finding orthogonal trajectories can be useful in various fields, such as engineering and physics, to solve problems involving intersecting curves.
3. How do you find orthogonal trajectories?
To find orthogonal trajectories, you need to first find the gradient of the original set of curves. Then, using the fact that the product of the gradients of two curves that are orthogonal is equal to -1, you can determine the equation for the orthogonal trajectories.
4. What is the significance of orthogonal trajectories?
Orthogonal trajectories have various applications, such as in the design of roads, bridges, and other structures, where intersecting curves need to be at right angles to ensure stability and efficiency.
5. Can orthogonal trajectories be found for any set of curves?
No, orthogonal trajectories can only be found for certain types of curves, such as circles, ellipses, and hyperbolas. They cannot be found for curves that do not have a smooth and continuous gradient.
