Find the period of the function
In summary, the period of the function f(x)=cos(cosx)+cos(sin x) is pi/2, found by plotting the function for multiples of pi/4 and using the identity for cosine sums.
utkarshakash
Find period of the function
the period of cosx=sinx=2∏. But here cosx and sinx are itself arguments to cosine function.
Ok, then f(x)=f(x+2pi) is definitely true. You just have to figure out is there are any shorter periods. Sketching a graph will help.
OK so how do you graph these kinds of functions manually?
Hint: Plot the function for multiples of pi/4.
ehild
ehild
Ok I plotted functions cos(cosx) and cos(sinx) separately for multiples of pi/4 and got the respectives periods as pi. But the given function is sum of both functions. So I took the LCM of periods of both functions which comes out to be pi. But the correct answer is pi/2.
Plot the whole function.
It stays the same if the terms are interchanged. What are cos(cos(x+pi/2)) and cos(sin(x+pi/2)) equal to? Expand the arguments.
ehild
You might also find the identity
$$\cos a + \cos b = 2\cos\left(\frac{a+b}{2}\right) \cos\left(\frac{a-b}{2}\right)$$ useful.
Related to Find the period of the function
1. What is the period of a function?
The period of a function is the distance along the x-axis between two consecutive points where the function has the same value. In other words, it is the length of one complete cycle of the function.
2. How do I find the period of a function?
To find the period of a function, you can use the formula: period = 2π/|b|, where b is the coefficient of the variable inside the trigonometric function. If there is no coefficient, the period is simply 2π.
3. Can the period of a function be negative?
No, the period of a function cannot be negative. It is always a positive value that represents the distance along the x-axis.
4. Can a function have more than one period?
Yes, some functions have multiple periods. This means that the function repeats itself at different intervals along the x-axis. In this case, you can choose any one of the periods to use in your calculations.
5. What is the relationship between the period and the frequency of a function?
The period and frequency of a function are inversely related. This means that as the period increases, the frequency decreases and vice versa. The frequency is the number of cycles of the function that occur per unit of time.
