Find the primes,for which a relation is satisfied
  • MHB
  • Thread starter evinda
  • Tags
    Relation
In summary: Nod)In summary, the conversation discusses finding the primes for which the equation $x^2 \equiv 13 \pmod p$ has a solution. It is shown that if $p$ is an odd prime of the form $1+13k$, then the original equation will have a solution. It is also noted that $p=2$ also satisfies the equation. The conversation also explores different possible solutions and concludes that all odd primes of the form $13k+1, 13k+4, 13k+9, 13k+3, 13k+12$ or $13k+10$ will satisfy the equation.
evinda
MHB
3,836
Hey! (Wave)
I have to find the primes $p$,for which $x^2 \equiv 13 \pmod p$ has a solution.
That's what I have tried:
$$\text{ Let } p>13:$$
We want that $\displaystyle{ \left ( \frac{13}{p} \right )}=1$
$$\left ( \frac{13}{p} \right )=(-1)^{\frac{13-1}{2} \cdot \frac{p-1}{2}}\left ( \frac{p}{13} \right ) $$
As $(-1)^{\frac{13-1}{2}=1, \text{ it must be: } \frac{p-1}{2}}\left ( \frac{p}{13} \right )=1$
So, $x^2 \equiv p \pmod{13}$ should have a solution..
Is that what I have tried right? Also,what else could I do? (Thinking)
Mathematics news on Phys.org
Hi! (Happy)
evinda said:
Hey! (Wave)
Looks good! (Nod)
What you can do is continue.
Which squares are there? (Thinking)
The first square is with $x=1$ in which case we get $p \equiv 1^2 \pmod{13}$.
So the original equation would have a solution if $p$ is an odd prime of the form $1+13k$.
And since $p$ has to be odd, we can also write it as $1+26k$.
First option that is prime is $53$.
And indeed, with e.g. $x=15$ we find $x^2 \equiv 15^2 \equiv 13 \pmod{53}$. (Mmm)
Btw, there's no need to require $p > 13$. You only need that it is odd.
So don't forget $p=2$. Is there a solution in that case? (Wondering)
I like Serena said:
Hi! (Happy)
Looks good! (Nod)
I created this array:
$$\begin{bmatrix}
x \ \ |& 1 & 2 &3 &4 &5 &6 \\
x^2 \ | & 1 & 4 & 9 & 3 & 12 & 10
\end{bmatrix}$$
So, is it only possible that $p \equiv 3 \pmod{13}$,because the only prime at the square residues is $3$ ,or am I wrong? (Sweating)
$$\begin{bmatrix}
\end{bmatrix}$$
Remember that $p \equiv 3 \pmod{13}$ means that $p=3+13k$. So this is not only $p=3$, but also $p=16, 29, ...$. As you can see $p=29$ is also a prime. (Wasntme)
Each of the residues will generate primes.
What about $x\equiv 0$? (Wondering)
Shouldn't it be $(x,13)=1$ ? (Thinking)
So can I just say that the relation is satisfied only for primes of the form $13k+3$? Or not? (Sweating)
I see no reason why it should.
Let's see what happens with $p=13$ in the original equation.
Does $x^2 \equiv 13 \pmod {13}$ have a solution? (Wondering)
There are many more.
Pick $x\equiv 1$ and we find $p \equiv 1 \pmod{13}$.
Now $1$ may not be a prime, but $1+4\cdot 13 = 53$ is a prime... (Thinking)
I thought it,because,according to my notes, if $x$ is a solution of $x^2 \equiv a \pmod m$,then $(x,m)=1$..So isn't it also like that in our case?
No,it has no solution,because $(13,13)=13 \neq 1$..or am I wrong?
$$\begin{bmatrix}
\end{bmatrix}$$
So..do we maybe see from the array that all the possible primes are of the form $13k+1, 13k+4, 13k+9 ,13k+3,13k+12 \text{ or } 13k+10$ ?? Or can't we do it like that? (Sweating)
If you look at the definition of the Legendre symbol, you'll see that $x\equiv a \equiv 0$ is allowed.
It does mean that $\left(\frac a p\right)$ has the special value of $0$.
Anyway, there's no need to put in that restriction.
As I see it, it should not be there unless specifically mentioned in the problem statement (which would not be unusual). (Wasntme)
If we drop that restriction, it does have a valid and sensible solution. (Wasntme)
$$\begin{bmatrix}
\end{bmatrix}$$
Yep. We can do it like that.
I'd say: odd primes of the form $13k\pm 1, 13k\pm 3, 13k\pm 4$, which is shorter.
Or: primes of the form $26k\pm 1, 26k\pm 3, 26k + 13 \pm 4$.
... and we might also mention the solution when $x\equiv 0$.
... and we might check the case $p=2$ separately, since we were only looking at odd primes. (Wink)
I understand (Sun) Thanks a lot! (Mmm)
FAQ: Find the primes,for which a relation is satisfied
What is the definition of a prime number?
A prime number is a positive integer that is only divisible by 1 and itself. In other words, it has exactly two factors.
How do you find the primes that satisfy a given relation?
To find the primes that satisfy a given relation, you would first need to understand the relation and its constraints. Then, you can use various mathematical techniques such as trial and error, sieving, or advanced algorithms to identify the primes that fit the relation.
Can any number be a prime if it satisfies a certain relation?
No, not every number that satisfies a given relation is a prime. Some numbers may have multiple factors, while others may have more than two factors. Only numbers that have exactly two factors, 1 and itself, are considered prime.
What are some common relations used to find primes?
Some common relations used to find primes include the Sieve of Eratosthenes, the Sieve of Sundaram, and the Sieve of Atkin. Other techniques such as trial division and Fermat's Little Theorem can also be used to find primes.
Can a prime satisfy more than one relation?
Yes, a prime can satisfy multiple relations. For example, the prime number 3 satisfies the relation of being a prime number, as well as the relation of being a Fibonacci prime (a prime that is also a Fibonacci number).
10K
