Find the product of all real solutions
  • MHB
  • Thread starter anemone
  • Tags
    Product
In summary, the product of all real solutions to the equation $\sqrt{2y-81}-\sqrt{1734-20y+4y^2}-\sqrt{81-2y}+\sqrt{4y^2+26y-129}=0$ is 0.
anemone
MHB
POTW Director
3,883
115
Find the product of all real solutions to the equation
$\sqrt{2y-81}-\sqrt{1734-20y+4y^2}-\sqrt{81-2y}+\sqrt{4y^2+26y-129}=0$.
Mathematics news on Phys.org
From the first surd, we have the condition $y \geqslant \frac{81}{2}$.
From the third surd, we have the condition $y \leqslant \frac{81}{2}$. But from the first condition, we have only one possible value of y for which both these expressions are defined i.e $\frac{81}{2}$
Substituting 81/2 in the given equation makes the first and the third surd equal to zero. Now we have to check if the remaining two surds give the same value when y=81/2 is substituted. Directly substituting 81/2 takes time (at least for me) so we take the reverse path. We equate the expressions inside the remaining surds to see at what value of y they are equal, if y comes out to be 81/2, then 81/2 is the answer.
$$4y^2+26y-129=4y^2-20y+1734 \Rightarrow 46y=1863 \Rightarrow y=\frac{81}{2}$$
Hence, the answer is $\boxed{\dfrac{81}{2}}$
Hello.
Has you healed?. I'd like to that you have recovered.
[tex]y=40.5[/tex]
[tex]\forall{y}>40.5 \ and \ \forall{y}<40.5 \ \rightarrow{}[/tex]
[tex]\rightarrow{} \sqrt{2y-81}-\sqrt{1734-20y+4y^2}-\sqrt{81-2y}+\sqrt{4y^2+26y-129} \neq{0}[/tex]
[tex]key \ term=\sqrt{81 \pm{2y}}[/tex]
Regards
Thanks to both of you for participating and you have gotten the right answer! Well done! :)
mente oscura said:
Hello.
Yes, I have recovered fully from food poisoning and thanks for asking!:eek:
I would approach this problem by first analyzing the equation and its components. The equation contains four square roots, which suggests that there could be multiple solutions. I would then proceed to solve the equation by isolating the variable, y, and finding its possible values.
After solving the equation, I would obtain a set of real solutions for y. To find the product of these solutions, I would multiply all of them together. This would give me the overall product of all real solutions to the equation.
However, I would also take into consideration any restrictions or limitations on the solutions. For example, if any of the solutions make the denominator of the equation equal to zero, then those solutions would not be considered as they would result in an undefined value.
In conclusion, the product of all real solutions to the given equation would be found by solving the equation and multiplying all of the real solutions together, while also considering any restrictions on the solutions.
FAQ: Find the product of all real solutions
What does "Find the product of all real solutions" mean?
The phrase "Find the product of all real solutions" refers to finding the product of all numbers that satisfy a given equation or problem. In mathematics, solutions are the values that make an equation true, and the product is the result of multiplying these solutions together.
Why is it important to find the product of all real solutions?
Finding the product of all real solutions is important because it helps us understand the relationship between different numbers and how they interact in an equation. It also allows us to solve more complex problems by breaking them down into smaller parts.
How do you find the product of all real solutions?
To find the product of all real solutions, you first need to identify the solutions to the given equation or problem. Then, you can multiply these solutions together to get the product. In some cases, you may need to use algebraic techniques to simplify the equation and make it easier to find the solutions.
What are some real-life applications of finding the product of all real solutions?
Finding the product of all real solutions has many real-life applications, such as in finance, engineering, and science. For example, in finance, the product of all real solutions can be used to calculate compound interest, while in engineering, it can be used to calculate the forces acting on a structure. In science, it can be used to model the growth of populations or the decay of radioactive materials.
Is it possible to have no real solutions in an equation?
Yes, it is possible to have no real solutions in an equation. This means that there is no value that can make the equation true. In other words, the equation has no solution in the set of real numbers. This can happen when the equation has imaginary solutions, or when the problem is not solvable within the given constraints.
