MHB Find the Radius and Center of a Circle
The equation of the circle is given as (x − 5)² + y² = 38. The radius of the circle is √38, and the center is located at the coordinates (5, 0). The standard form of a circle's equation indicates that the number on the right side represents the radius squared, hence the need for the square root. Clarification was provided on why 38 is not squared in the context of the radius. The discussion concludes with an affirmation of the correct interpretation of the circle's parameters.
squexy
Can someone show me how to resolve this question?
A particular circle in the standard (x,y) coordinate
plane has an equation of (x − 5)2 + y2 = 38. What are
the radius of the circle, in coordinate units, and the
coordinates of the center of the circle?
radius center
F. √38 ( 5,0)
G. 19 ( 5,0)
H. 38 ( 5,0)
J. √38 (−5,0)
K. 19 (−5,0)The answer is F
Mathematics news on Phys.org
plane has an equation of $(x − 5)^2 + y^2 = 38$. What are
radius center
F. √38 ( 5,0)
G. 19 ( 5,0)
H. 38 ( 5,0)
J. √38 (−5,0)
Hi squexy! Welcome to MHB! :)
The general equation of a circle is:
$$(x-a)^2 + (y-b)^2 = r^2$$
where $r$ is the radius and $(a,b)$ is the center.
Your equation can be written as:
$$(x − 5)^2 + (y-0)^2 = (\sqrt{38})^2$$
This shows that the radius is $\sqrt{38}$ and the center is $(5,0)$.
Thank you for the answer.
Why is 38 in square root?
(x−5)2+(y−0)2= (√38 )²
Since the equation given is (x−5)2+y2=38. shouldn't the equation transferred to the circle formula be written as:
(x−5)2+(y−0)2= (38 )²
Well, $(38)^2 = 38 \cdot 38 = 1444$. This does not match the $38$ in the original equation.
What we need is a number for $r$ that when squared gives us $38$. This is what the square root is. It means that $(\sqrt 38)^2 = \sqrt 38 \cdot \sqrt 38 = 38$, which is what is required.
Look again at post #2.
The form we should have:
$(x - a)^2 + (y - b)^2 = r^2$
What we do have:
$(x - 5)^2 + y^2 = 38$.
It's clear from this that the "$x$" part is already what we need, so $a = 5$.
The "$y$" part is a bit trickier, we solve:
$(y - b)^2 = y^2$
$y^2 - 2by + b^2 = y^2$.
$b(b - 2y) = 0$. <---this has to be true for ALL $y$, and not just when $y = \dfrac{b}{2}$ ($b$ is a constant).
We conclude that $b = 0$.
The only thing left to do is solve:
$r^2 = 38$.
This happens when $r = \pm \sqrt{38}$.
Since a radius is always positive, we take the positive square root for $r$.
The number on the RHS of the standard circle equation is the radius SQUARED, not the radius. For example, a circle of radius 3, centered at the origin has equation:
$x^2 + y^2 = 9$ <---note we have 9, not 3.
$(9,0)$ does not lie on this circle, since:
$9^2 + 0^2 = 81 \neq 9$.
$(3,0)$ DOES lie on this circle, since:
$3^2 + 0^2 = 9$.
Thanks ^.^
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
