Find the radius of the sector adjoining a triangle
In summary, the conversation discusses finding the radius of a sector given its angle and area using the formula $\frac{1}{2}(2\pi)(r)=\frac{1}{2}\left(\frac{40}{360} \cdot \pi\right)r^2$. The final solution is r=9 cm.
mathlearn
331
https://i.imgsafe.org/5172eee94d.jpg
For a closer look click https://i.imgsafe.org/5172eee94d.jpg
We know that the area of the sector should be $\frac{40}{360}$*$\frac{22}{7}$*$r$*r
Any ideas on how to begin?
Many Thanks:)
Mathematics news on Phys.org
We know the area of the triangle and the area of the sector are equal, so using the respective formula for those areas we may state:
\(\displaystyle \frac{1}{2}(2\pi)(r)=\frac{1}{2}\left(40^{\circ}\cdot\frac{\pi}{180^{\circ}}\right)r^2\)
What do you get when solving for $r$?
$\displaystyle \frac{1}{2}(2\pi)(r)=\frac{1}{2}\left(40^{\circ}\cdot\frac{\pi}{180^{\circ}}\right)r^2$
$\displaystyle (\pi)(r)=\left(\frac{\pi}{9^{\circ}}\right)r^2$
$9 \displaystyle (\pi)(r)=\pi r^2$
Now Let's use factorization to find r ,
$9 \displaystyle (\pi r)=(\pi r) * r $
$9 cm =r$
Now to check whether It is correct,
$ \displaystyle \frac{1}{2} * 2 * \frac{22}{7} * 9 = \frac{22}{7} * \frac{40}{360}* 9^2$
$ \displaystyle \frac{22}{7} * 9 = \frac{22}{7} * \frac{1}{9}* 9^2$
$ \displaystyle \frac{22}{7} * 9 = \frac{22}{7} * \frac{1}{9}* 9 * 9$
$ \displaystyle \frac{22}{7} * 9 = \frac{22}{7} * 9 $
Correct I guess ? :)
Many Thanks :)
Yes, I also got:
\(\displaystyle r=9\text{ cm}\)
In your second line, the degrees would have "cancelled" and so you would just have:
\(\displaystyle (\pi)(r)=\left(\frac{\pi}{9}\right)r^2\)
When checking the answer, I would simply use the $\pi$ symbol rather than a rational approximation for $\pi$. :)
:) Thanks For the advice.
FAQ: Find the radius of the sector adjoining a triangle
What is a sector adjoining a triangle?
A sector adjoining a triangle refers to the region formed by a triangle and the arc of a circle that connects the two endpoints of the triangle's base.
How do you find the radius of a sector adjoining a triangle?
To find the radius of a sector adjoining a triangle, you can use the following formula: r = (b^2 + 4h^2)/(8h), where b is the length of the triangle's base and h is the height of the triangle.
Can the radius of a sector adjoining a triangle be negative?
No, the radius of a sector adjoining a triangle cannot be negative. It is a physical measurement and therefore cannot have a negative value.
Are there any specific units for the radius of a sector adjoining a triangle?
The units for the radius of a sector adjoining a triangle will depend on the units used for the base and height of the triangle. For example, if the base is measured in meters and the height is measured in centimeters, the radius will also be in centimeters.
Can the radius of a sector adjoining a triangle be larger than the length of the triangle's base?
Yes, it is possible for the radius of a sector adjoining a triangle to be larger than the length of the triangle's base. This will happen when the height of the triangle is small in comparison to the length of the base.
