Albert1
- 1,221
find the radius of the small circle O_2:
[sp]Albert said:find the radius of the small circle O_2:
https://www.physicsforums.com/attachments/1660
Opalg said:Edit. Yet again, ILS got there first (and I never even noticed).
I like Serena said:Must be my new avatar.
Sometimes it makes me feel imaginary.
To find the radius of a small circle, you need to measure the distance from the center of the circle to any point on the circle's edge. This distance is the radius, and it can be measured using a ruler or a compass.
The formula for finding the radius of a small circle is r = d/2, where r is the radius and d is the diameter of the circle. The diameter is the distance across the circle passing through the center.
Yes, you can find the radius of a small circle if you know the circumference. The formula for this is r = C/2π, where r is the radius and C is the circumference of the circle. π is a constant value of approximately 3.14.
To find the radius of a small circle if you know the area, you can use the formula r = √(A/π), where r is the radius and A is the area of the circle. Again, π is a constant value of approximately 3.14.
No, the radius and diameter of a small circle are not always the same. The diameter is always twice the length of the radius, but they can have different numerical values depending on the size of the circle.
