Find the Ratio of BG to FG in a Figure with Given Side Lengths
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, "BG" and "FG" stand for base-to-top ratio and floor-to-ground ratio respectively in this context. To find the ratio of BG to FG in a figure, the lengths of the base, top, floor, and ground must be measured and the resulting ratio can be expressed as a fraction. The ratio is important in determining proportions and relationships in a figure, and can be found using techniques such as physically measuring the sides or using mathematical formulas. However, there are some limitations to finding the ratio, such as the figure must be two-dimensional and have precise measurements.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
In the figure below, $AB=AF=15,\,FD=12,\,BD=18,\,BE=24$ and $CF=17$. Find \(\displaystyle \frac{BG}{FG}\).
https://www.physicsforums.com/attachments/5959._xfImport
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week problem. :(
You can see the proposed solution as follows:
By applying the Stewart's theorem on triangle $ABD$ and the line $BF$, we have:
$15^2\cdot 12+18^2 \cdot 15 =BF^2\cdot 27+15\cdot 12\cdot 27$
So $BF=10$ and so $EF=24-10=14$.
Again we use the Stewart's theorem on triangle $ABE$ and the line $AF$, we have:
$AE^2\cdot 10+15^2 \cdot 14 =15^2\cdot 24+14\cdot 10\cdot 24$
So $AE=\sqrt{561}$.
By Stewart's theorem on triangle $AED$ and the line $EF$, we have:
$ED^2\cdot 15+561 \cdot 12 =14^2\cdot 27+12\cdot 15\cdot 27$
So $ED=2\sqrt{57}$.
By Stewart's theorem on triangle $CFE$ and the line $FD$, we have:
$14^2\cdot CD+17^2 \cdot 2\sqrt{57} =12^2\cdot (CD+2\sqrt{57})+2\sqrt{57}\cdot 12\cdot CD \cdot (CD+2\sqrt{57})$
So $CD=\sqrt{57}$ and $CE=CD+DE=3\sqrt{57}$.
Note that $DG=18-BG$ and apply Menelaus' theorem to triangle $BED$ and the line through $C,\,G$ and $F$ to get \(\displaystyle 3\cdot\frac{18-BG}{BG}\cdot \frac{10}{14}=1\), so \(\displaystyle BG=\frac{135}{11}\).
Similarly, $CG=17-FG$, so applying Menelaus's theorem to triangle $CFE$ and the line through $B,\,G$ and $D$ we get \(\displaystyle \frac{24}{10}\cdot \frac{FG}{17-FG}\cdot \frac{1}{2}=1\) so \(\displaystyle FG=\frac{85}{11}\).
Therefore \(\displaystyle \frac{BG}{FG}=\frac{27}{17}\).
FAQ: Find the Ratio of BG to FG in a Figure with Given Side Lengths
What does the term "BG" and "FG" stand for in this context?
In this context, "BG" stands for base-to-top ratio, and "FG" stands for floor-to-ground ratio. These are two common ratios used in geometry to compare the lengths of different sides in a figure.
How do you find the ratio of BG to FG in a given figure?
To find the ratio of BG to FG, you need to measure the lengths of the base, top, floor, and ground in the figure. Then, you divide the base length by the top length to find the base-to-top ratio, and divide the floor length by the ground length to find the floor-to-ground ratio. The ratio of BG to FG can then be expressed as a fraction with the base-to-top ratio as the numerator and the floor-to-ground ratio as the denominator.
Why is it important to find the ratio of BG to FG in a figure?
The ratio of BG to FG is important because it helps to determine the proportions and relationships between different sides in a figure. This can be useful in various fields such as architecture, engineering, and design, where precise measurements and proportions are crucial.
What are some common techniques used to find the ratio of BG to FG in a figure?
Some common techniques used to find the ratio of BG to FG include using a ruler or measuring tape to physically measure the lengths of the sides, using a protractor to measure angles, or using mathematical formulas and calculations based on the given side lengths.
Are there any limitations to finding the ratio of BG to FG in a figure?
Yes, there are some limitations to finding the ratio of BG to FG in a figure. For example, the figure must be two-dimensional and have clear and distinct sides that can be measured. Additionally, the given side lengths must be accurate and precise in order to calculate an accurate ratio.
