Find the remainder when 1/f(x) is divided by x+1
  • Thread starter Thread starter DeathKnight
    Remainder
The discussion centers on finding the remainder when the rational function 1/f(x) is divided by x+1, where f(x) = 8x^3 + 4x - 3. Participants clarify that the concept of "remainder" typically applies to polynomial division, not rational functions. It is noted that dividing 1 by a polynomial does not yield a remainder in the traditional sense, as rational functions do not operate like integers. The conversation suggests that the original question may stem from a misunderstanding of how remainders work in polynomial versus rational function division. Ultimately, the conclusion is that there is no remainder when dividing 1/f(x) by x+1.
DeathKnight
It is given that f(x)=8x^3+4x-3. The question is: Find the remainder when 1/f(x) is divided by x+1. My textbook says the remainder does not exist? I just can't solve it.
Thanks in advance for any help.
Abdullah
Exactly what is meant by "remainder" here?
For example, if I ask "what is the remainder when 17 is divided by 6" the answer is 5:
6 divides into 17 twice with remainder 17-12= 5. That's because I'm working with integers.
However, if I ask "what is the remainder when 1/17 is divided by 6", the question no longer makes sense. 1/17 is not an integer so I cannot be talking about integer operations- and there is no "remainder" in rational number division.
In algebra, "polynomials" correspond to "integers" and "rational functions" to rational numbers. If the problem were "what is the remainder when 8x^3+ 4x- 3 is divided by x+1" it's easy to see that the answer is -15: 8x^3+ 4x- 3= (x+1)(8x^2- 8x+ 12)- 15.
But I don't know what is meant by "remainder" in dividing the rational function 1/(8x^3+ 4x- 3) by x+1.
Maybe that is exactly what he's lookin for.
I think he's supposed to use polynomial long division or something called like this. Anywho, it might help you if you looked at it like so
\frac{(1/(8x^3+4x-3))}{(x+1)} is also \frac{1}{(x+1)(8x^3+4x-3)}.
The way i remember it, you have to find what you would multiply the denomenator by to get the numerator(sort of useless really), but the above fraction has a definite answer with no remainder. For an example of the "long division" (x^2+3x-5)/(x+1) = x+2 - (7/(x+1))*
*this would be the remainder.
