Find the RMS current drawn from the 240 Vrms supply
To find the RMS current from a 240 Vrms supply, the total impedance of the circuit must be calculated correctly. The initial approach of simplifying parallel resistors to 0.5 Ohm was incorrect; instead, the left 1 Ohm resistor is in series with a parallel circuit that includes another 1 Ohm resistor and additional components. Kirchhoff's laws were applied, but there were errors in the equations, particularly mixing voltages and currents. The correct method involves deriving the complex impedance of the parallel circuit to accurately solve for the currents, which should yield an expected result of 126 A with a phase difference of 6.4 degrees. Clarifying the use of resistance in the equations is essential for accurate calculations.
youmei0426
For the circuit below find:
the rms current drawn from the 240 V rms supply if the frequency is 50 Hz, and the phase of the current relative to the applied voltage.
Z(R) = R
Z(C) = -i/(wC)
Z(L) = iwL
where Z is complex impedance, R is resistance, w is angular frequency, L is inductance and C is capacitance
My first idea was to find the total impedance of the circuit, but I think viewing the two parallel resistors as one resistor of 0.5 Ohm isn't the correct way? I don't know how to simply this series / parallel circuit further to find Z total.
Then I tried to use Kirchhoff's law to the loop on the left, and got the equation 240 - I1R - (I1-I2)R = 0. Since R = `1, the equation was simplified into
I2 - 2I1 + 240 = 0.
Doing the same thing for the loop on the right, and getting the voltages by using IZ, I had the equation
-I2*(-i/(wC)) - I2*iwL - I2 + (I1 - I2)=0
Making the real part of the above equation to zero and solving for the two equations, I got I1 = 160A and I2 = 80A. However, the answer is supposed to be 126 A with a phase difference of 6.4 degree.
Am I approaching the question in the wrong way?? Thanks in advance for your help!
You don't. You have the left ##1 \ \Omega## in series with a parallel circuit consisting of
##1\ \Omega## in the left branch and
## \displaystyle {1\over j \omega C} + j\omega L + 1 \ \Omega## in the right branch.
You need an equation for the complex impedance of this parallel circuit. Simple.
That is indeed what is required
I agree with the first idea (just not the 0.5 Ohms). Equation for a parallel circuit is a good approach, but KCL or KVL should have worked too.
Something in your equations for the right loop doesn't look right to me because you are describing voltages... first terms are voltages, but the last ones are currents. I'm not sure if it's a problem from transcribing or if this is what you put into the calculator (I'm not even sure if it truly is wrong or right I'm just saying my gut feeling is telling me something doesn't look right for the reason of adding currents with voltages). This is the equation that doesn't look right to me (from original post): -I2*(-i/(wC)) - I2*iwL - I2 + (I1 - I2)=0
Ah okay, I will just have to work through the very long equations to find the phase and real part then. Thanks!
Ah since the impedance is equal to the resistance which is 1 Ohm in both cases, I wrote just I2 and (I1-I2) instead of I2*R and (I1-I2)*R. Sorry should have made that clearer!
No need to be sorry. I should have noticed it was 1 Ohm :) Thanks!
Likes youmei0426
  • · Replies 18 ·
