Find the set that contains the real solution to an equation
In summary: I have found the solution - the answer is (A) but i am not sure if i should post it here...I'll have to check the numbers when I get home, but I think that this is somewhat simpler:3. The Attempt at a SolutionI think you might be on the right track. I am not sure if there is a simpler way to solve this but I think you are on the right track. I will let you know if I find anything simpler.I think you might be on the right track. I am not sure if there is a simpler way to solve this but I think you are on the right track. I will let you know if I find anything simpler.
  • #36
I get ##x^2= 3##, so i choose a) as my final answer :).
  • #37
##x = \sqrt{3}## is not a solution.
  • #38
I made an algebraic mistake at the end. I now gey ##x^2 = 4## no mistakes i think. So is this the solution?
  • #39
Yes, I got that too.
But what is the final answer? :)
  • #40
I didn't realize you were all intent on solving the equation!
  • #41
2 is found in interval ##[\sqrt{3}, 2\sqrt{3})## so that should be correct
  • #42
Indeed.
There are ways to solve this exercise without actually doing the whole computation.
@PeroK ? :)
Likes diredragon
  • #43
Samy_A said:
Indeed.
There are ways to resolve this exercise without actually doing the whole computation.
@PeroK ? :)
I assumed a solution would be hard to find, so I concentrated on identifying the possible interval. But, it would have been a much better problem just to ask you to solve the equation and forget the multiple choice. I think the extra effort was worth it to get a solution!
In fact, if you replace ##\sqrt{3}## by any positive ##\alpha## in the original equation, then you get ##x = \frac{2\alpha}{\sqrt{3}}##.
Likes diredragon
