Find the Shear and Moment on the Beam
  • Thread starter Thread starter Northbysouth
    Beam Moment Shear
To derive the shear force V and bending moment M for the cantilever beam, the initial equations were established based on the loading conditions. The maximum absolute shear force calculated was 2109.19 lb, while the maximum bending moment was found to be 9789.17 lb·ft. The calculations involved integrating the loading function and applying boundary conditions, ensuring equilibrium at the beam's free end. It was noted that the fixed end reaction and moment must be considered for accurate results. The discussion emphasized the importance of including arbitrary constants during integration to avoid errors in calculations.
Northbysouth
Derive expressions for the shear force V and bending moment M as functions of x in the cantilever beam loaded as shown. Then answer the questions.
At x = 2 ft,
V =
M =
At x = 9.3 ft
V =
M =
I have attached an image of the question
The maximum (absolute value) shear force in the beamis 2109.19 lb
The maximum (absolute value) bending moment in the beam is lb·ft
W = -dV/dx
dM = Vdx
First I found the equation w = w0+kx2
When x = 0
120 lb/ft = w0 +k(0)2
Hence w0 = 120 lb/ft
When x = 11.3'
320 lb/ft = 120 + k(11.3)2
k = 1.566
Hence:
w = 120 + 1.566x2\
To find the shear, V, I took the integral of w because:
w = -dV/dx hence
-∫w = V
V = -120x - 1.566x2
Thus when x = 2
V = -120(2) - 1.566(2)3
V = -244.176
When x = 9.3
V = -120(9.3) - 1.566(9.3)3
V = -1535.87
For the Moments I did the following
dm = Vdx
m = ∫V
m = ∫-120x - 0.522x3
m = -0.135x4-60x2
When x = 2
m = -242.
When x = 9.3
m = -6165.607
Then to try and calculate the maximum shear:
V = -120(11.3)-0.522(11.3)3
V = -2109.19
But it wants the absolute value, hence V = 2109.19
For the max bending moment:
m = -0.1325(11.3)3 - 60x2
m = -9789.17
But it wants the absolute value, hence V = 9789.17
Except for the max shear all of my values are wrong and I'm at a loss for what I should do. Help would be greatly appreciated. Thank you
No image attached.
Sorry. I have now fixed it. Thank you for pointing that out.
In order to obtain the correct shear force and bending moment diagrams for this beam, you must first find the fixed end reaction and moment which keep the beam in equilibrium. Remember, at the free end, V = M = 0.
Although steamking has wise words, in this case you CAN work from the right hand end without the reactions. Let e be the distance from the RH end, positive to the left... Ehen ev is .. and Mv is ... (use the definitions). When you have finished, the reactions should appear when v=11.3'. You then have a check on any errors made.Northbysouth, when you integrated, did you forget the arbitrary constant?
  • · Replies 18 ·
