Find the smallest positive integer k
  • MHB
  • Thread starter anemone
In summary, the conversation is about solving a math problem involving finding the smallest positive integer k such that tan k^o = (cos 2020^o + sin 2020^o)/(cos 2020^o - sin 2020^o). Dan and kaliprasad have both solved the problem and are discussing their methods. Dan acknowledges that kaliprasad's method is more efficient, but still posts his own solution. They both congratulate each other on their solutions.
anemone
MHB
POTW Director
3,883
115
Find the smallest positive integer $k$ such that
$\tan k^{\circ}=\dfrac{\cos 2020^{\circ}+\sin 2020^{\circ}}{\cos 2020^{\circ}-\sin 2020^{\circ}}$
Mathematics news on Phys.org
You are going to keep me up all night on this one. Again!
-Dan
We know tan (45 + A) = ( tan 45 + tan A)/( tan 45- tan A)
= ( 1+ sin A/cos A)/( 1- sin A / cos A)
= ( cos A + sin A)/(cos A – sin A)
So ( cos 2020 + sin 2020)/( cos 2020 – sin 2020)
= tan (45 + 2020) = tan (2065) = (tan 2065 mod 180) or tan 85 degrees
Hence k = 85 degrees
-Dan
Hi Dan,
Even though kaliprasad has already cracked it, there are still many other methods to solve the problems and I can't wait to read your solution too!:cool:
Well done, kaliprasad!
I finally got it. However kaliprasad's method takes a couple of shortcuts I didn't see so I'm not going to post.
It was a very satisfying problem. Thank you.
-Dan
I'll post it if you wish.
First, an angle of 2020 corresponds to an angle of 220, which is a reference angle of 40 in Quadrant III. So
\(\displaystyle \frac{cos(2020) + sin(2020)}{cos(2020) - sin(2020)} = \frac{-cos(40) - sin(40)}{-cos(40) + sin(40)}\)
\(\displaystyle = \frac{cos(40) + sin(40)}{cos(40) - sin(40)}\)
\(\displaystyle = \frac{cos(40) + sin(40)}{cos(40) - sin(40)} \cdot \frac{cos(40) + sin(40)}{cos(40) + sin(40)}\)
\(\displaystyle = \frac{cos^2(40) + 2sin(40)~cos(40) + sin^2(40)}{cos^2(40) - sin^2(40)}\)
After some simplifying:
\(\displaystyle tan(k) = \frac{sin(80) + 1}{cos(80)}\)
Now look at the "averaging formula" for tangent:
\(\displaystyle tan \left ( \frac{\alpha + \beta}{2} \right ) = \frac{sin( \alpha ) + sin(\beta )}{cos( \alpha ) + cos( \beta )}\)
If we let \(\displaystyle \alpha = 80\) and \(\displaystyle \beta = 90\)
\(\displaystyle tan \left ( \frac{80 + 90}{2} \right ) = tan(85) = \frac{sin(80) + 1}{cos(80)} = tan(k)\)
Thus the smallest angle k is thus 85 degrees.
Like I said there are some short-cuts. I tend to do things the "hard" way. (Wink)
-Dan
-Dan
-Dan
Hi Dan,
Hey, when I said I was looking forward to seeing your solution, I was only joking, as we all know if someone has already cracked a challenge problem, then the chances that others will look into it and solve it differently is very unlikely.
But I appreciate that you solved the problem and posted your solution too and my method is more or less the same as yours.:eek:
Bravo, Dan!:cool:
FAQ: Find the smallest positive integer k
What does "smallest positive integer k" mean?
The "smallest positive integer k" refers to the smallest whole number that is greater than 0. In other words, it is the smallest number in the set of positive integers.
How do you find the smallest positive integer k?
To find the smallest positive integer k, you can use a variety of methods such as trial and error, mathematical equations, or computer algorithms. The method used will depend on the specific problem and context.
What is the significance of finding the smallest positive integer k?
Finding the smallest positive integer k can be useful in many mathematical and scientific applications. It can help determine the minimum value in a data set, find the smallest possible solution to a problem, or determine the smallest necessary quantity in a chemical reaction, among other things.
Is the smallest positive integer k always unique?
Yes, the smallest positive integer k is always unique. This is because there is only one smallest number in the set of positive integers. If two numbers are found to be the smallest, then they are essentially the same number.
Can the smallest positive integer k be a decimal or fraction?
No, the smallest positive integer k must be a whole number. Decimals and fractions are not considered part of the set of positive integers, so they cannot be the smallest positive integer k.
