Find the smallest value for the polynomial
In summary, the smallest value among the given options is the product of the non-real zeroes of the quartic polynomial P(x) = x^4 + ax^3 + bx^2 + cx + d. This can be determined by considering the properties of the graph and the values of the coefficients and zeroes of the polynomial. The context of this problem is a high school contest, where the use of calculus is allowed.
Loststudent22
100
Member warned that the homework template must be used
The graph below shows a portion of the curve defined by the quartic polynomial P(x) = x^4 + ax^3 + bx^2 + cx + d. Which of the following is the smallest?https://imgur.com/a/1VuGSiA(A) P(-1) (B) The product of the zeros of P (C) The product of the non-real zeros of P (D) The sum of the coefficients of P (E) The sum of the real zeros of PI know that P(-1) = 1-a+b-c+d Product of zeroes is d. Real zeroes are around 1.7 and 3.85, so product of non-reals is d/(1.7*3.85) Sum of the coefficients is 1+a+b+c+d. Sum of the zeros is -a and that P(0)=d and P(1)=1+a+b+c+d. How am I supposed to tell which is smallest with this information though?
I think that this problem requires you to elliminate the potential answers that could not be answers. For example, both real zeroes are positive, so their product would also be positive. Any nonreal zeroes have to occur in conjugate pairs. For this problem I believe that the nonreal zeroes would be purely imaginary; if so, their product would also be positive. Can you eliminate any more possibilities in continuing with this kind of analysis?
Also, even though this was posted in the Precalc section, I suspect that more information can be obtained by looking at the first and second derivatives, noticing where both the first and second derivatives are negative, positive, or zero.
What's the context for this problem? Is it in a textbook of some kind? Was the problem given in a math class? If so, was it a calculus class?
Likes Loststudent22
Well from the graph P(-1) is positive so I can eliminate that. Also at P(0) I know that D is also positive. Yet at P(1) the graph get smaller so I can assume that a and c are probably negative which would mean that the sum of the cofficients might be negative?It was a high school contest problem I came across so I assume that calculus could be used.
Hmm c is the product of the x-values of the minima and maxima of the function (zeroes of the derivative). c is either 0 or slightly negative. So would that mean its the correct choice then?
The sum of the real zeroes is at least 4, while the product of the non-real zeroes is d divided by the product of the real zeroes, which is smaller than 6/3 = 2, which beats out all the other ones.
Related to Find the smallest value for the polynomial
1. What is a polynomial?
A polynomial is an expression that consists of variables, coefficients, and exponents. It can have one or more terms, and the degree of the polynomial is determined by the highest exponent present.
2. How do you find the smallest value for a polynomial?
To find the smallest value for a polynomial, you can use methods such as factoring, completing the square, or using the quadratic formula. These methods involve manipulating the polynomial into a form where the smallest value can be easily determined.
3. Can a polynomial have more than one smallest value?
No, a polynomial can only have one smallest value. This value is also known as the minimum value, and it is the lowest point on the graph of the polynomial.
4. What is the significance of finding the smallest value for a polynomial?
Finding the smallest value for a polynomial can help determine the minimum or maximum values of a given function. It can also be used to solve optimization problems where the goal is to minimize a certain quantity.
5. Are there any real-life applications for finding the smallest value of a polynomial?
Yes, there are many real-life applications for finding the smallest value of a polynomial. For example, it can be used in engineering to optimize the design of structures or in economics to determine the minimum production cost for a product.
  • Math POTW for Secondary and High School Students
  • General Math
