Find the Solution to $a^2-b^2$ with $a+bi$ a Root of $z(z+i)(z+3i)=2002i$
  • MHB
  • Thread starter Albert1
  • Tags
    Root
In summary: The other two solutions are then $w = 5 \pm \sqrt{118}$, which correspond to the two complex roots of the original equation. From there, we can find the value of $a^2-b^2 = 93$.In summary, the problem presents an equation with the unknown variable $z$ and the imaginary unit $i$. The given conditions are that $a,b>0$ and $i=\sqrt{-1}$. The task is to find the value of $a^2-b^2$ when $a+bi$ is a root of the equation $z(z+i)(z+3i)=2002i$. Using substitution and factorization, the solution is obtained as $a
Albert1
1,221
$a+bi$ is a root of :$z(z+i)(z+3i)=2002i$
here :$a,b>0$ and $i=\sqrt {-1}$
please find :$a^2-b^2=?$
Mathematics news on Phys.org
[sp]$$0 = z(z+i)(z+3i) - 2002i = z^3 + 4iz^2 - 3z - 2002i = (z+14i)(z^2 - 10iz - 143).$$ One solution is $z = a+bi = -14i.$ But in that case, $b = -14 <0$ and we want a solution with $b>0$. So we must look for one of the solutions of $z^2 - 10iz - 143 = 0.$ These are $z = 5i \pm\sqrt{118}$, and the required solution is $z = \sqrt{118} + 5i$. So $a = \sqrt{118}$, $b = 5$, and $a^2-b^2 = 118 - 25 = 93.$[/sp]
very good slution !
As an addendum, an efficient way to notice the $z = -14i$ root is to notice that $2002 = 11 \cdot 13 \cdot 14$.
[sp]What I actually did was to notice that if you put $z=iw$ then the equation $z(z+i)(z+3i) - 2002i = 0$ becomes $w(w+1)(w+3) + 2002 = 0$, with all the coefficients real. You can then easily find the solution $w = -14$ by factorising $2002 = 11 \cdot 13 \cdot 14$.[/sp]
FAQ: Find the Solution to $a^2-b^2$ with $a+bi$ a Root of $z(z+i)(z+3i)=2002i$
What is the solution to $a^2-b^2$ with $a+bi$ as a root of $z(z+i)(z+3i)=2002i$?
The solution to $a^2-b^2$ can be found by solving the given equation using the root $a+bi$. This will result in two values for $a^2-b^2$, since complex roots always come in conjugate pairs.
How can I find the roots of $z(z+i)(z+3i)=2002i$?
The easiest way to find the roots of this equation is by using the quadratic formula. You can also use the factoring method if possible.
Can there be more than one solution to $a^2-b^2$ for a given root $a+bi$?
Yes, since complex roots always come in conjugate pairs, there will be two solutions to $a^2-b^2$ for a given root $a+bi$.
How do complex roots affect the solution to $a^2-b^2$?
Complex roots will result in two solutions for $a^2-b^2$, which will be complex conjugates of each other. This means that the real parts will be the same, but the imaginary parts will have opposite signs.
Is there a way to simplify $a^2-b^2$ with complex roots?
Yes, you can use the difference of squares formula to simplify $a^2-b^2$ when dealing with complex roots. This will result in a real number as the solution.
