Find the Solution to $x^2+\frac{1}{x^2}=23$: x+$\frac{1}{x}$
  • MHB
  • Thread starter mathlearn
In summary, the conversation discusses finding the value of $x+\frac{1}{x}$ when $x^2+\frac{1}{x^2}=23$. The participants suggest squaring $x+\frac{1}{x}$ and then rearranging the terms to find the solution. Eventually, it is determined that the answer is 5.
mathlearn
331
If $x^2+\frac{1}{x^2}=23$. Find $x+\frac{1}{x}$
Any Ideas on how to begin? (Happy)
Mathematics news on Phys.org
What happens when you square $x+\frac{1}{x}$ ?
Hey (Wave) Opalg,
Thank's for the catch , It's a sum of two squares
$\Bigl(x+\frac{1}{x}\Bigr)^2.=\Bigl(x+\frac{1}{x}\Bigr) \Bigl(x+\frac{1}{x}\Bigr).$
mathlearn said:
Hey (Wave) Opalg,
Yes, of course, [tex]\left(x+ \frac{1}{x}\right)^2= \left(x+ \frac{1}{x}\right)\left(x+ \frac{1}{x}\right)[/tex] but that is not the "sum of two squares"!
What did you get as an answer for this problem?
Hey (Wave) HallsofIvy,
Still I am unable to derive an answer..(Happy)(Smile)
mathlearn said:
Hey (Wave) Opalg,
Have you tried Opalg's suggestion? Multiply it out and see what you get.
-Dan
I think this is what you meant originally,
$\Bigl(x+\frac{1}{x}\Bigr)^2=x^2+2+\frac{1}{x^2}$
Now rearranging,
$\Bigl(x+\frac{1}{x}\Bigr)^2=x^2+\frac{1}{x^2}+2$
It is given that $x^2+\frac{1}{x^2}=23$
$\Bigl(x+\frac{1}{x}\Bigr)^2=23+2$
$\Bigl(x+\frac{1}{x}\Bigr)^2=25$
Many Thanks :rolleyes:
FAQ: Find the Solution to $x^2+\frac{1}{x^2}=23$: x+$\frac{1}{x}$
What is the equation "Find the Solution to $x^2+\frac{1}{x^2}=23$: x+$\frac{1}{x}$"?
The equation is a quadratic equation where the variable x is raised to the second power and also appears in the denominator as a fraction with a constant value of 1.
What does "solution" mean in this context?
In this context, "solution" refers to the value or values of x that make the equation true. In other words, it is the value or values that satisfy the equation.
How do you solve this equation?
To solve this equation, you can use the quadratic formula. First, rearrange the equation to have all terms on one side and set it equal to 0. Then, plug in the values for a, b, and c into the formula and solve for x. You can also try factoring the equation or using other algebraic methods.
Are there multiple solutions to this equation?
Yes, there are typically two solutions to a quadratic equation. However, in some cases, there may be only one solution or no real solutions at all.
What are the real solutions to this equation?
The real solutions to this equation are the values of x that make the equation true and are also real numbers. In this case, the solutions are x = 2 and x = -2.
