MHB Find the Solutions of a Quadratic Equation Using the Quadratic Formula
  • Thread starter Thread starter mathlearn
The discussion focuses on solving the quadratic equation x^2 + 4x - 8 = 0 using the quadratic formula. The solutions derived are x = 1.46 and x = -5.46, with the latter being calculated as -2 - 2√3. Participants confirm the correct application of the formula and clarify a potential typing error regarding the second solution. The conversation emphasizes the importance of accuracy in mathematical expressions. Overall, the quadratic formula effectively provides the required solutions to the equation.
mathlearn
By completing the square or by any other method , find the solutions of the quadratic equation , to two decimal places $x^2+4x-8=0$.
Using the quadratic formula,(Smile)
$x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$.
$x=\frac{-4\pm\sqrt{16+32}}{2}$.
$x=\frac{-4\pm\sqrt{48}}{2}$.
$x=\frac{-4\pm\sqrt{3}\sqrt{16}}{2}$.
$x=\frac{-4\pm 4\sqrt{3}}{2}$.
$x={-2\pm 2\sqrt{3}}$.
$x= 1.46$.
As the problem states there is another value for x which is -5.46, How to derive it using the quadratic formula ? (Happy)
Mathematics news on Phys.org
$x= 1.46$.
$x= 1.46$.
You have another solution: [math]-2 - 2 \sqrt{3}[/math]
-Dan
topsquark said:
You have another solution: [math]-2 - 2 \sqrt{2}[/math]
-Dan
(Happy) Thank you top squark
(Nod) A typing mistake I guess, [math]-2 - 2 \sqrt{3}[/math] , I guess it should be . Correct ? (Thinking)
Yes. Thanks for the catch!
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
