MHB Find the square of the distance
  • Thread starter Thread starter anemone
    Square
To find the square of the distance from point B to the center of the circle, the radius is given as √50 cm. The lengths of segments AB and BC are 6 cm and 2 cm, respectively, with angle ABC being a right angle. Using the Pythagorean theorem, the distance from B to the center can be calculated by determining the coordinates of points A, B, and C based on the given lengths. The final calculation leads to the square of the distance being 50 cm². This problem illustrates the application of geometry in determining distances in a circular context.
anemone
MHB
POTW Director
The radius of the circle is $\sqrt{50}$ cm, the length of $AB$ is 6 cm and that of $BC$ is 2 cm. The angle $ABC$ is a right angle. Find the square of the distance from $B$ to the center of the circle.
[TIKZ]
\draw[purple,thick] (0,0) arc (70:328:3);
\coordinate[label=above:A] (A) at (0,0);
\coordinate[label=left:B] (B) at (0,-4.43);
\coordinate[label=right:C] (C) at (1.48,-4.43);
\draw[thick] (A) -- (B) -- (C);
[/TIKZ]
Mathematics news on Phys.org
[TIKZ][scale=1.3]
\coordinate[label=above:$A$] (A) at (0,0);
\coordinate[label=left:$B$] (B) at (0,-4.43);
\coordinate[label=right:$C$] (C) at (1.48,-4.43);
\coordinate[label=left:$O$] (O) at (-1.03,-2.82);
\coordinate[label=right:$N$] (N) at (0.74,-2.21);
\draw (C) -- (A) -- (O) -- (B) ;
\draw (N) -- (O) ;
\draw (0.12,-0.8) node{$\beta$} ;
\draw (-0.15,-0.8) node{$\alpha$} ;
[/TIKZ]
In the diagram, $O$ is the centre of the circle, $N$ is the foot of the perpendicular from $O$ to $AC$, and the angles $\alpha$, $\beta$ are as shown.
By Pythagoras, $AC = \sqrt{40}$, so $AN = \sqrt{10}$. By Pythagoras again, $ON = \sqrt{40}$. Then $\tan\beta = \frac13$ and $\tan(\alpha + \beta) = 2$. Therefore $$\tan\alpha = \frac{2-\frac13}{1 + \frac23} = 1$$ and so $\alpha = 45^\circ$.
Now use the cosine rule in triangle $OAB$ to get $OB^2 = 50 + 36 - 2*\sqrt{50}*6*\frac1{\sqrt2} = 86 - 60 = 26.$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
