evinda
MHB
- 3,836
Hello! (Wave)
Let a particle be forced to move over the sphere $x^2+y^2+z^2=1$, that is subject to gravitational forces while also to an additional "dynamic" $V(x,y,z)=x+y$. Find the stable equilibrium points , if they exist.I have found a similar example:
Let $\vec{F}$ be the gravity field near the surface of the earth, i.e. let $\vec{F}=(F_x, F_y, F_z)$ where $F_x=0, F_y=0$ and $F_z=-mg$, where $g$ is the acceleration du to the gravity. Which are the equilibrium points, if a point particle of mass $m$ is restricted to the sphere $\phi(x,y,z)=x^2+y^2+z^2-r^2=0(r>0)$ ? Which of these are stable?
The solution is the following:We notice that $\vec{F}$ is a gradient field with "dynamic" $V=mgz$. Using the method of Lagrange multipliers to get the possible extrema , we have the equations
$$\nabla V= \lambda \nabla \phi \\ \phi=0$$
or equivalently$$0=2 \lambda x \\ 0= 2 \lambda y \\mg=2 \lambda z \\ x^2+y^2+z^2-r^2=0$$
The solution of the system of equations is $x=0, y=0, z = \pm r, \lambda= \pm \frac{mg}{2r}$.
From a theorem we get that $P_1=(0,0,-r)$ and $P_2=(0,0,r)$ are equilibrium points. Checking $V=mgz$ we get that $P_1$ is stable, but $P_2$ isn't.Do we consider also in our case a gravity field $\vec{F}$ ? If so what will this represent? (Sweating)If so then $\vec{F}=-\nabla V=-(1,1,0)$, right?
Then using the method of Lagrange multipliers we get the following extrema:
$$\left( \frac{1}{\sqrt{2}}, \frac{1}{\sqrt{2}}\right), \left( -\frac{1}{\sqrt{2}}, -\frac{1}{\sqrt{2}}\right)$$Right?
