Find the sum of all positive integers a
In summary, the formula for finding the sum of all positive integers a is (n(n+1))/2, and can also be found using the formula Sn = (n(a1 + an))/2. This sum can be calculated using a calculator, and there is a shortcut or trick using the formula (n(n+1))/2. However, it is not possible to find the sum if the series is infinite, as it would approach infinity and cannot be accurately calculated.
anemone
MHB
POTW Director
3,883
115
Find the sum of all positive integers $a$ such that $\sqrt{\sqrt{(a+500)^2-250000}-a}$ is an integer.
Mathematics news on Phys.org
let m=$\sqrt{\sqrt{(a+500)^2-250000}-a}----(*)$
n=$\sqrt{(a+500)^2-250000}< a+500$
$m<\sqrt{500}\,\, or\,\, m\leq 22$---(1)
$n=\sqrt {a(a+1000)}=\sqrt{a(a+2^35^3)}$
min(a)=125=$5^3$
and $\sqrt {250}<m \,\, or \, 16\leq m$----(2)
from (1) and (2) put m=16,17,18,19,20,21,22 to (*)
we get m=20 where $a=800=2^55^2$ is the only solution
min(a)=125=$5^3$
Well done Albert! Thanks for participating.:)
FAQ: Find the sum of all positive integers a
What is the formula for finding the sum of all positive integers a?
The formula for finding the sum of all positive integers a is (n(n+1))/2, where n is the highest positive integer in the series.
How do you find the sum of all positive integers a using a mathematical series?
To find the sum of all positive integers a using a mathematical series, use the formula Sn = (n(a1 + an))/2, where n is the number of terms in the series, a1 is the first term, and an is the last term.
Can you use a calculator to find the sum of all positive integers a?
Yes, you can use a calculator to find the sum of all positive integers a by plugging in the values into the formula (n(n+1))/2 or Sn = (n(a1 + an))/2.
Is there a shortcut or trick to finding the sum of all positive integers a?
Yes, there is a shortcut or trick to finding the sum of all positive integers a. You can use the formula (n(n+1))/2 to find the sum without having to manually add all the numbers in the series.
Can you find the sum of all positive integers a if the series is infinite?
No, it is not possible to find the sum of all positive integers a if the series is infinite. The sum would approach infinity and cannot be calculated accurately.
