Find the Sum of k when $k\in N$ and $\sqrt {k^2+48k} \in N$
  • MHB
  • Thread starter Albert1
  • Tags
    Sum
In summary, the value of k can vary depending on the specific natural number that is being used, but it will always be a natural number itself. To solve for k in the equation √(k²+48k)=n, where n is a natural number, you can use algebraic manipulation or trial and error. K must be a natural number in order for the equation to be solved, and examples of values that satisfy this equation include 3, 6, 9, 12, and 15. There is no specific method or formula to solve this type of equation, as it depends on the specific equation and natural number given.
Albert1
1,221
$k\in N$ , and $\sqrt {k^2+48k} $ $\in N$
find $\sum k$
Mathematics news on Phys.org
let $\sqrt{k^2+48k} = n$
so $k^2+48k=n^2$
or $(k+24)^2 -n^2= 576\cdots(1)$
or $(k+24+n)(k+24-n) = 576$
further from (1) both (k+24) and n have to be even or odd so (k+24+n) and (k+ 24-n) both are even and k+24+n > 24
so we get
$(k+24+n, k+24-n) = (288,2)$ giving $k = 121$
or $(144,4)$ giving $k= 50$
or $(72,8)$ giving $k=16$
or$(48,12)$ giving $k=6$
or $(36,16)$ giving $k =2$
or $(32,18)$ giving $k=1$
so sum of $k = 1 + 2 + 6+16 +50+121= 196$
edit: I had missed a solution
I missed (96,6) giving k= 27 giving sum of k = 223.
so $k^2+48k=n^2$
so we get
thanks for participation , but your answer is not correct,there is one answer missing
Yes I missed (96,6) giving k= 27 giving sum of k = 221.
Note I shall edit the post also
sum of k=223
Albert said:
sum of k=223
OOPS one more mistake
FAQ: Find the Sum of k when $k\in N$ and $\sqrt {k^2+48k} \in N$
What is the value of k if the square root of k squared plus 48k is a natural number?
The value of k can vary depending on the specific natural number that is being used. However, k will always be a natural number itself.
How do I solve for k in the equation √(k²+48k)=n, where n is a natural number?
To solve for k, you can use algebraic manipulation to isolate k on one side of the equation. You can also use trial and error by plugging in different values for k until you find the one that makes the equation equal to the given natural number, n.
Can k be a decimal or fraction in this equation?
No, k must be a natural number in order for the square root of k squared plus 48k to be a natural number. Fractions or decimals would result in a non-natural number when plugged into the equation.
What are some examples of values for k that satisfy this equation?
Some examples of values for k that satisfy this equation include 3, 6, 9, 12, and 15. These values make the square root of k squared plus 48k equal to the natural numbers 5, 8, 11, 14, and 17, respectively.
Is there a specific method or formula to solve this type of equation?
No, there is no specific method or formula to solve this equation. Different strategies, such as algebraic manipulation or trial and error, can be used to solve for k. It ultimately depends on the specific equation and natural number that is given.
