MHB Find the sum of the first 11 terms of given series
  • Thread starter Thread starter anemone
    Series Sum Terms
The discussion revolves around finding the sum of the first 11 terms of the series $$\frac{19}{99}+\frac{199}{999}+\frac{1999}{9999}+ \cdots$$ The original poster attempts to derive the nth term and expresses it as a sum, but struggles to simplify it effectively. A suggestion is made to separate the sums and avoid invalid cancellations, indicating that a common denominator might be necessary. Ultimately, it is agreed that using a computer algebra system (CAS) may be the most efficient way to solve the problem. The conversation highlights the complexity of the series and the challenges in manual calculation.
anemone
MHB
POTW Director
Hi MHB,
This problem vexes me until my mind hurts.
Problem:
Find the sum of the first 11 terms of the series $$\frac{19}{99}+\frac{199}{999}+\frac{1999}{9999}+ \cdots$$
Attempt:
I managed only to find the expression of the nth term of the given series and I got
$$\frac{19}{99}+\frac{199}{999}+\frac{1999}{9999}+ \cdots+11^{th} term=\sum_{k=1}^{11} \frac{2(10)^k-1}{10(10^k)-1}=\sum_{k=1}^{11} \left( \frac{1}{5}-\frac{4}{5(10(10^k)-1)} \right)$$
$$=\frac{11}{5}-\frac{4}{5} \left( \frac{1}{99}+\frac{1}{999}+ \cdots + 11^{th} term \right)$$
and I noticed this $$\sum_{k=1}^{11} \frac{4}{5(10(10^k)-1)} $$isn't a geometric series and thus by rewriting the problem in this manner is a dead end and it won't solve the problem.
So I tried to break the given series as follows:
$$\frac{19}{99}+\frac{199}{999}+\frac{1999}{9999}+ \cdots+11^{th} term=(\frac{1}{99}+\frac{9}{99})+(\frac{1}{999}+ \frac{2(99)}{999})+ \cdots+11th term$$
$$=\frac{1}{99}+\frac{1}{999}+ \cdots + 11^{th} term+2 \left( \frac{99}{999}+\frac{999}{9999}+ \cdots + 11^{th} term \right)$$and I know this is another cul-de-sac and I am getting so mad right now, I just don't see how to approach the problem.
Could anyone help me, please?
Thanks in advance.
Mathematics news on Phys.org
anemone said:
Hi MHB,
Problem:
Attempt:
Alas, I don't think you made a valid move there. It is perilous to cancel things that aren't factors. You can separate out the two sums:
$$ \sum_{k=1}^{11} \frac{2(10)^k-1}{10^{k+1}-1}=
2\sum_{k=1}^{11} \frac{10^k}{10^{k+1}-1}
- \sum_{k=1}^{11} \frac{1}{10^{k+1}-1}.$$
I'm not sure where this lands you. I would just hand it over to a CAS at this point.
You could try get a common denominator, which would look something like
$$\prod_{j=1}^{11}(10^{j+1}-1).$$
The resulting expression would be rather tedious to sort out.
Thank you for the reply, Ackbach!:)
Yes, after spending more time to attempt to overcome the problem on my own, I agree that it's best to let the problem be handled by wolfram or any other CAS in order to get the exact value of the sum.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
