Find the sum of the first n terms
  • MHB
  • Thread starter anemone
  • Tags
    Sum Terms
In summary, the formula for finding the sum of the first n terms of a series is S = (n/2)(a + l), and for an arithmetic series, it is S = (n/2)(2a + (n-1)d). An arithmetic series has a constant difference between consecutive terms, while a geometric series has a constant ratio. The sum of the first n terms of a series can be negative if the terms alternate between positive and negative values. To find the sum of the first n terms of a series using sigma notation, write out the terms and substitute the value of n.
anemone
MHB
POTW Director
3,883
115
Evaluate the sum $\displaystyle \sum_{i=0}^n \tan^{-1} \dfrac{1}{i^2+i+1}$.
Mathematics news on Phys.org
My solution:
We are given to evaluate:
\(\displaystyle S_n=\sum_{k=0}^n\left[\tan^{-1}\left(\frac{1}{k^2+k+1} \right) \right]\)
Using the identity:
\(\displaystyle \tan^{-1}(x)=\cot^{-1}\left(\frac{1}{x} \right)\)
we may write:
\(\displaystyle S_n=\sum_{k=0}^n\left[\cot^{-1}\left(k^2+k+1 \right) \right]\)
Now, using the fact that:
\(\displaystyle k^2+k+1=\frac{k(k+1)+1}{(k+1)-k}\)
and the identity:
\(\displaystyle \cot(\alpha-\beta)=\frac{\cot(\alpha)\cot(\beta)+1}{\cot(\beta)-\cot(\alpha)}\)
We may now write:
\(\displaystyle S_n=\sum_{k=0}^n\left[\cot^{-1}(k)-\cot^{-1}(k+1) \right]\)
This is a telescoping series, hence:
\(\displaystyle S_n=\cot^{-1}(0)-\cot^{-1}(n+1)=\frac{\pi}{2}-\cot^{-1}(n+1)\)
Using the identity:
\(\displaystyle \tan^{-1}(x)+\cot^{-1}(x)=\frac{\pi}{2}\)
We may also write:
\(\displaystyle S_n=\tan^{-1}(n+1)\)
And so we have found:
\(\displaystyle \sum_{k=0}^n\left[\tan^{-1}\left(\frac{1}{k^2+k+1} \right) \right]=\tan^{-1}(n+1)\)
MarkFL said:
My solution:
Using the identity:
we may write:
and the identity:
We may now write:
Using the identity:
We may also write:
Aww...that is a fabulous way to tackle the problem! Bravo, MarkFL! (Inlove)(Clapping)(drink)
A generalization is $$ \sum_{k=0}^{n} \arctan \left( \frac{a}{a^{2}k^{2}+a(a+2b)k +(1+ab+b^{2})} \right) = \arctan \Big(a(n+1)+b \Big) - \arctan(b)$$
where $ak+b >0$
where $ak+b >0$
Thanks for your input, Random Variable!:)
FAQ: Find the sum of the first n terms
What is the formula for finding the sum of the first n terms of a series?
The formula for finding the sum of the first n terms of a series is S = (n/2)(a + l), where S represents the sum, n is the number of terms, a is the first term, and l is the last term.
How do you find the sum of the first n terms of an arithmetic series?
To find the sum of the first n terms of an arithmetic series, you can use the formula S = (n/2)(2a + (n-1)d), where S represents the sum, n is the number of terms, a is the first term, and d is the common difference between terms.
What is the difference between an arithmetic series and a geometric series?
An arithmetic series is a sequence of numbers where the difference between consecutive terms is constant, while a geometric series is a sequence of numbers where each term is multiplied by a constant ratio to get the next term.
Can the sum of the first n terms of a series be negative?
Yes, the sum of the first n terms of a series can be negative if the terms of the series alternate between positive and negative values.
How do you use sigma notation to find the sum of the first n terms of a series?
To use sigma notation to find the sum of the first n terms of a series, you would write out the terms of the series in the sigma notation and then substitute the value of n into the expression.
