Find the surface charge density that will stop a proton
In summary: If you're not sure how the proton will land, then you'll want to include a fringing effect in your solution.
Patdon10
85
2. The attempt at a solution
I have the solution, but it's pretty confusing so I want to see if anyone else can walk me through step by step. The first step is pretty clear...You have to find the acceleration that the proton will experience as it moves towards the upper (positive) plate.
F = ma
a = F/m
F = qE
a = (qE)/m
a = -eE/m
From there what do you do? Set it up in a kinematics equation? How does the surface charge density come into play?
I think you might want to include fringing effects. Consider the electric field from a uniform finite plate.
Yes, you'll want to set up a kinematics equation. In particular, you're interested in the motion in the vertical direction. The surface charge density will determine the strength of the field between the plates (how?).
Note: A quicker solution might be had by going via conservation of energy. Then you can skip the kinematic equation involving position, acceleration, etc..
What's the initial kinetic energy of the proton in the vertical direction? What's the energy gained (or lost) by a proton moving through a potential difference of V volts?
alright, so I need to set up a kinematics. You have to avoid the variable t, so you can use the equation:
V_f^2 = v_i^2 + 2ad
The final velocity will be 0
0 = vi^2 + 2ad
vi^2/2a = d
Since we only care about velocity and displacement in the y direction, the equation changes to
d = (v_i^2)sin(30)/2(-e*E/m)
What do you do from here?
Since you know d can't be any more than 1cm do you plug that in, and solve for...E?
oooo man. Then from E, you can solve for the linear charge density...
correct?
I don't know how to find the energy gained when it's moving through a potential difference. Maybe in a few weeks we'll go over that?
There is something misleading about the picture, how are you guaranteed the proton to land at x = W?
I'm not. But I feel like I don't care about that? All I need to figure out is the charge density to keep it from hitting the upper capacitor.
Here's a spoiler then: ΔE = qV
Charge multiplied by the voltage though which the charge "falls" is the energy imparted (or extracted).
It's the basis of the electron-volt energy unit. One eV is the energy gained by an object (particle) with the charge of an electron (an elementary charge) falling though a 1 Volt potential.
If your proton has a certain KE in the vertical direction and its traveling against a potential difference (due to an electric field), then it will come to a halt when q*V matches the KE. Keep in mind that the units of an electric field are Volts/meter.
correct?
Yes, that'll work.
I did this problem and my algebraic expression is large. I have't plugged in the numbers yet...
I also assumed the proton lands at x = W
FAQ: Find the surface charge density that will stop a proton
What is surface charge density?
Surface charge density is a measure of the amount of electric charge present on a surface per unit area.
How does surface charge density affect a proton?
The surface charge density on a surface can affect a proton by exerting an electric force on it. This force may either attract or repel the proton depending on the sign of the charge.
What factors determine the surface charge density required to stop a proton?
The surface charge density needed to stop a proton depends on the mass and velocity of the proton, as well as the strength of the electric field acting on it.
How can I calculate the surface charge density needed to stop a proton?
The surface charge density can be calculated using the formula: ρ = q/A, where ρ is the surface charge density, q is the charge of the proton, and A is the surface area.
Can surface charge density be manipulated to stop a proton?
Yes, the surface charge density can be manipulated by changing the amount of charge on the surface or by altering the surface area. However, it is important to note that there may be limitations based on the strength of the electric field and the properties of the surface material.
