Find the temperature coefficient of metal X
In summary, the formula R(50*C)=R(20*C) (1+a*lΔTl) can be used to find the temperature coefficient of metal X, as the graph does not show a linear relationship between V and I. It is also possible to use R/Ω as a linear relationship with T/*C and find R=(dR/dT)T+c, where dR/dT and c are constants for the same metal. The graph may not be part of a measured lab assignment, but the question was asked out of curiosity.
icystrike
445
Metal X
1) since the graph does not show that V is linearly related with I , is it right for me to apply the formula
R(50*C)=R(20*C) (1+ a lΔTl )
to find the temperature coefficient of metal X ?
2) R/Ω is linearly related with T/*C ?
If yes, will R=(dR/dT)T+c ?
Whereby dR/dT and c are constants that a fixed for the similar metal
please can someone answer to my question..
LowlyPion said:
1) looks to behave that way.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/restmp.html
For an introductory course I'd say this is what they would want you to use.
Is this graph part of a measured lab assignment?
the graph is not part of the measure lab assignment.
I ask this question simply because of curiosity.
Thank you for answering my question , your help is greatly appreciated.
FAQ: Find the temperature coefficient of metal X
What is the temperature coefficient of metal X?
The temperature coefficient of metal X is a measure of how much the resistance of the metal changes as the temperature changes. It is typically represented by the symbol α and is measured in units of ohms per degree Celsius (Ω/°C).
How is the temperature coefficient of metal X determined?
The temperature coefficient of metal X can be determined by measuring the resistance of the metal at two different temperatures and using the formula α = (R2-R1)/(R1(T2-T1)), where R1 and R2 are the resistances at the two temperatures and T1 and T2 are the corresponding temperatures in degrees Celsius.
What factors can affect the temperature coefficient of metal X?
The temperature coefficient of metal X can be affected by several factors, including the type and composition of the metal, impurities present in the metal, and the temperature range in which it is being measured. It may also vary slightly depending on the method used to measure it.
Why is it important to know the temperature coefficient of metal X?
Knowing the temperature coefficient of metal X is important because it allows us to understand how the metal will behave in different temperature conditions. This information is crucial in many applications, such as designing electronic circuits, measuring temperature accurately, and selecting materials for specific temperature requirements.
Can the temperature coefficient of metal X change over time?
Yes, the temperature coefficient of metal X can change over time due to factors such as aging, corrosion, and changes in temperature range. It is important to regularly recalibrate and re-measure the temperature coefficient to ensure accuracy in its use.
9K
