jdawg
- 367
- 2
A static thrust stand is to be designed for testing a jet engine. The inlet conditions for the test are an inlet area of 1 {m2}, inlet velocity of 250 {m/s}, and gage static pressure of -22.5 {kPa}. The expected conditions at the 0.3 {m2} outlet are an exhaust gas velocity of 444 {m/s}, gage static pressure of 0 {kPa} and temperature of 268 {K}. Find the thrust the engine produces. Assume constant mass flow rate through the engine (i.e. mass of fuel in negligible) and that the gauge pressure is atmospheric pressure
First I calculated the total pressure entering and exiting the turbine:
(ρv2/2)+P+ρgh=Ptotal
The first term being dynamic pressure, the second being static pressure, and the third being hydrostatic pressure. I assumed hydrostatic pressure was negligible since I was given no information about the height.
Ptotal,1=15.78 kPa
Ptotal,2=120.75 kPa
Then I used F=P2A2
And found the force to be 402.5 kN
Does what I did make sense? I'm not really sure if this is the proper way to find the force of the thrust.
