Find the Time and write it as a power
  • Thread starter waxer1987
  • Tags
    Power Time
In summary, to find the time given the acceleration, initial velocity, and final velocity, use the formula (Vfinal - Vinitial) / a = t. In this case, the answer is 6.0 x 10^1s. to write a value as a power of 10, count the number of decimal places you need to move the decimal point to get a single digit, and that is your power of ten.
waxer1987
Acceleration: -0.20m/s^2[E] Initial Velocity: 24m/s[E] Final Velocity 12m/s Time(s): ?
I need to find the Time and write it as a power. The answer is 6.0 x 10^1s. I don't understand how they got this or how to write it as a power.
-0.20m/s^2 = 24m/s[E] - 12m/s[E] / Time
Time = 24m/s - 12m/s + 0.20m/s^2
Time = 24m/s - 12m/s + 0.20m/s^2This step is wrong.
It should be (24m/s - 12m/s) / 0.20m/s^2.
writing in power means write 125 as 1.25x10^2
Well, this is really two problems-- one the physics problem of finding the time given the initial velocity, final velocity, and acceleration, and the second being how to write a given value as a power of 10.
It looks like you tried to apply the formula
(Vfinal - Vinitial) / t = a, but you made an algebraic error-- you added the acceleration to both sides, instead of dividing by it!
Once you get the answer, you can write it as a power of 10. There may be some formal way of doing this, but for some value, you can just look at how many decimal places you need to move the decimal point to get a single digit, and that's your power of ten. Each decimal place is a power of ten. For example, say your value is 1023. You need to move the decimal point three spots to the left, so it would be written:
1023 = 1.023 x 10^3
Hope this helps!
FAQ: Find the Time and write it as a power
How do you find the time and write it as a power?
The process of finding the time and writing it as a power involves converting the time into seconds and then expressing it as a base number raised to a power. For example, if the time is 2 minutes, which is equivalent to 120 seconds, it can be written as 120 = 102.
Why is it important to write time as a power?
Writing time as a power helps to express large amounts of time in a more concise and easier to understand format. It also allows for easier calculations and comparisons between different units of time.
Can you give an example of finding the time and writing it as a power?
Sure, let's say we want to express 1 hour as a power. Since 1 hour is equivalent to 3600 seconds, it can be written as 3600 = 602. This means that 1 hour is equal to 60 seconds raised to the power of 2.
What is the benefit of using powers to represent time?
Using powers to represent time allows for easier calculations and conversions between different units of time. It also helps to simplify complex expressions involving time, making them easier to understand and work with.
Are there any limitations to writing time as a power?
While writing time as a power can be useful in many situations, it may not always be the most practical or appropriate method. For example, when dealing with fractions of a second or very small units of time, it may be more useful to express them in decimal form rather than as a power.
