Find the time at which the bead will start slipping
In summary: When I looked at this, I wrote:Let ##f_s = \mu N## be the maximum frictional force.That avoids any confusion (or potential loss of marks in an exam). If you simply use a frictional force of ##\mu N## without any comment, then you risk a pedantic examiner taking issue with you.In summary,A long horizontal rod has a bead which can slide along its length and is initially placed at a distance ## L ## from one end A of the rod.The rod starts from rest in angular motion about A with a constant angular acceleration ##\alpha## .If the coefficient of friction between the rod and the bead is ## µ## and gravity is neglected
Kaushik
282
A long horizontal rod has a bead which can slide along its length and is initially placed at a distance ## L ## from one end A of the rod.The rod starts from rest in angular motion about A with a constant angular acceleration ##\alpha## .If the coefficient of friction between the rod and the bead is ## µ## and gravity is neglected then what is the time after which the bead starts slipping.
Kaushik said:
Problem Statement: A long horizontal rod has a bead which can slide along its length and is initially placed at a distance ## L ## from one end A of the rod.The rod starts from rest in angular motion about A with a constant angular acceleration ##\alpha## .If the coefficient of friction between the rod and the bead is ## µ## and gravity is neglected then what is the time after which the bead starts slipping.
Relevant Equations: -
How far can you get on your own?
Likes Kaushik
  • Centripetal force is the frictional force.
  • With respect to the bead, it experiences a frictional force which pulls it towards the center with radius = L and centrifugal force (pseudo force). ## ƒ_s ≤ µN = m\omega^2L##
  • ##\alpha = \omega /t=> \omega^2 = (\alpha t)^2##
  • Normal force acting on it is given the tangential acceleration, ## N =(m)a_t = (m)\alpha L##
  • ##µ(m)(\alpha L) ≤ m \omega ^2 L = m(\alpha)^2(t)^2(L)##
  • ## t ≥ \sqrt{\frac{µ}{\alpha}}##
Is it correct?
Likes PeroK
  • With respect to the bead, it experiences a frictional force which pulls it towards the center with radius = L and centrifugal force (pseudo force). ## µN = m\omega^2L##
  • ##µ(m)(\alpha L) = m \omega ^2 L = m(\alpha)^2(t)^2(L)##
  • ## t = \sqrt{\frac{µ}{\alpha}}##
Is it correct?
Sorry, I'm not getting alerts any more, so I missed your post.
Yes, that all looks good. One minor point is that you are dealing with the maximum possible frictional force. The actual frictional force is less than this, and is equal to the required centripetal force.
Likes Kaushik
Is the edited answer correct?
In general it's a good idea always to describe ##\mu N## as the maximum frictional force. That was all I meant. Your solution stood as it was. But, you didn't say precisely what ##f_s## denoted.
Likes Kaushik
Related to Find the time at which the bead will start slipping
What is the equation for finding the time at which the bead will start slipping?
The equation for finding the time at which the bead will start slipping is: t = μmg/ma, where t is the time, μ is the coefficient of friction, m is the mass of the bead, g is the acceleration due to gravity, and a is the acceleration of the bead.
How do you calculate the coefficient of friction for a given surface?
The coefficient of friction can be calculated by dividing the force of friction by the normal force between the surfaces. The force of friction can be measured using a spring scale, and the normal force can be calculated using the weight of the object and the angle of the surface.
What factors can affect the time at which the bead will start slipping?
The time at which the bead will start slipping can be affected by the coefficient of friction, the mass and shape of the bead, the angle and material of the surface, and the initial velocity of the bead.
Can the equation be used for any shape or size of the bead?
Yes, the equation can be used for any shape or size of the bead as long as the mass and acceleration are known. However, the coefficient of friction may vary depending on the shape and material of the bead.
Why is it important to know the time at which the bead will start slipping?
Knowing the time at which the bead will start slipping can help prevent accidents and ensure the safety of people working with or near the bead. It can also be used to optimize processes and improve efficiency in industries where beads or other objects may slide on surfaces.
14K
