Find the time required for an airplane flight
In summary, a small aircraft traveling at 80 m/s in still air is scheduled to fly 600 km due west on a day with a wind speed of 18 m/s blowing from south to north. The aircraft travels in a direction of 13 degrees SW. The problem is to find the time required for the trip. One approach is to use vector diagrams and the velocity of the plane w.r.t. earth to solve for the time.
eddiedowen
A small aircraft cruises at a speed of 80 m/s in still air. The plane is scheduld to fly to a destination that is 600 km due west on a day on which the wind is blowing at 18 m/s from south to north.
It travels in a direction of 13 degrees SW. Find the time required for the trip.
So, what have you done till now? Start with the vector diagrams.
I have the diagram all written out, I just don't know how to find the time. I have everything else solved except for the time.
Do you have the velocity of plane w.r.t. earth? If not find that and use it to find time.
Likes 1 person
eddie, you must fill out the template before we are allowed to help you.
FAQ: Find the time required for an airplane flight
How do you calculate the time required for an airplane flight?
The time required for an airplane flight can be calculated by dividing the distance of the flight by the speed of the airplane. This will give you the estimated time it will take for the airplane to reach its destination.
What factors affect the time required for an airplane flight?
The time required for an airplane flight can be affected by various factors such as the distance of the flight, the speed of the airplane, weather conditions, air traffic, and any potential delays.
Can the time required for an airplane flight change during the flight?
Yes, the time required for an airplane flight can change during the flight due to various factors such as weather conditions, air traffic, and any potential delays. These factors can cause the airplane to slow down or change its route, which can affect the overall time of the flight.
How accurate are the estimated times for airplane flights?
The estimated times for airplane flights are usually accurate, but they can vary depending on the factors mentioned above. Airlines usually provide estimated times based on the average flight speed and other factors, but it is not uncommon for the actual flight time to be longer or shorter than the estimated time.
Is the time required for an airplane flight the same for all flights?
No, the time required for an airplane flight can vary depending on the distance, speed, and other factors mentioned above. Shorter flights will have a shorter time required compared to longer flights, and flights with favorable conditions will have a shorter time compared to flights with adverse conditions.
