MHB Find the Two-Digit Number: Exceeds by 4 and 1 Less Than Twice the Units Digit
  • Thread starter Thread starter paulmdrdo1
    Units
The problem involves finding a two-digit number where the tens digit exceeds the units digit by 4 and is also 1 less than twice the units digit. The correct interpretation leads to the tens digit being 9 and the units digit being 5, resulting in the number 95. A miscalculation occurred when the tens digit was incorrectly identified as the units digit, leading to confusion. Ultimately, the correct two-digit number is 95, confirmed by multiple calculations. The discussion emphasizes the importance of correctly interpreting the relationships between the digits.
paulmdrdo1
The tens digit of a certain two-digit number exceeds the units digit by 4 and is 1 less than twice the units digit. Find the two-digit number.
this is my solution,
let $x=$ tens digit, $x-4=$units digit.
$x=2(x-4)-1$ then, $x=9$ and $9-4=5$
the number is 59
but when I let $x=$ units digit and $x+4=$ tens digit I get the answer of 95.
can you tell me which one is correct?
tnahks!
Mathematics news on Phys.org
Re: digit problems.
I let $T$ be the tens digit and $U$ be the units digit, and so:
$$T=U+4=2U-1\implies U=5\implies T=9$$
And so the two digit number is $95$.
Re: digit problems.
paulmdrdo said:
let $x=$ tens digit... $x=9$ and $9-4=5$
the number is 59
No, it's 95.
Re: digit problems.
the number is 59
tnahks!
In your solution you said: "let $x$ be the tens digit", and then solved for $x$ to obtain $x = 9$.
Thus your number is 9_ (ninety-something).
Solving for the unit digit, which you have as $x - 4$, you obtained: 5.
Thus your number is 95.
You solved it correctly, but misinterpreted your own solution.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
