Find the Value of a Polynomial with Given Constraints - POTW #250 Jan 17th, 2017
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the purpose of "Find the Value of a Polynomial with Given Constraints" is to practice using mathematical concepts to find the value of a given polynomial. The key steps to solving this problem are identifying the polynomial, determining constraints, using mathematical operations to simplify the polynomial, and checking the solution against the constraints. A polynomial is a mathematical expression used to represent a relationship between variables and constraints. Constraints are important in this problem as they ensure a valid solution. This problem relates to real-world applications of mathematics by requiring mathematical skills and critical thinking, and by being useful in solving real-world problems involving equations and relationships between variables.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $P$ be a polynomial such that $P(x)=a_0+a_1x+\cdots+a_nx^n$ where $a_0,\,a_1,\cdots$ are non-negative integer. Given that $P(1)=4$ and $P(5)=152$, find $P(6)$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. lfdahl
Solution from lfdahl:
All coefficients ($a_i$) belong to the set: $\{0,1,2,3,...\}$
It must be a cubic polynomial, because a quartic and higher would exceed $P(5) = 152$.
So, we´re left with the function: $P(x) = a_0+a_1x+a_2x^2+a_3x^3$.
$P(1) = 4$, implies $a_0,a_1,a_2,a_3 \in \{0,1,2,3,4\}$ under the restriction: $a_0+a_1+a_2+a_3 = 4.$
Clearly, $a_3 = 1$, because any higher value would imply: $P(5) > 152$.
On the other hand: $a_3 = 0$, is not possible, because a quadratic polynomial cannot reach the value $152$.
Thus far, we have the polynomial value: $5^3 = 125$. We still need 27 to reach $P(5)$.
The only way to obtain $27$ with the quadratic part of the polynomial is the combination:
$2 + x^2$ ($a_0=2$, $a_1=0$ and $a_2 = 1$).
Hence, $P$ has the explicit form: $P(x) = 2 + x^2+x^3$, and
$P(6) = 2 + 36 + 216 = 254.$
FAQ: Find the Value of a Polynomial with Given Constraints - POTW #250 Jan 17th, 2017
What is the purpose of "Find the Value of a Polynomial with Given Constraints"?
The purpose of this problem is to practice using mathematical concepts such as polynomials and constraints to find the value of a given polynomial.
What are the key steps to solving this problem?
The key steps to solving this problem are: 1) identifying the given polynomial, 2) determining the constraints or conditions that must be met, 3) using mathematical operations to simplify the polynomial and solve for the unknown variable, and 4) checking to make sure the solution satisfies the given constraints.
What is a polynomial and how is it used in this problem?
A polynomial is a mathematical expression consisting of variables, coefficients, and mathematical operations such as addition, subtraction, multiplication, and division. It is used in this problem to represent a mathematical relationship between the unknown variable and the given constraints.
What are constraints and why are they important in this problem?
Constraints are conditions or limitations that must be satisfied in order for a solution to be valid. In this problem, constraints are used to narrow down the possible values of the unknown variable and ensure that the solution is a valid solution to the given polynomial.
How does solving this problem relate to real-world applications of mathematics?
Solving this problem requires a combination of mathematical skills and critical thinking, which are important in many fields such as engineering, economics, and physics. Additionally, being able to find the value of a polynomial with given constraints is a useful skill in solving real-world problems involving equations and relationships between variables.
