Find the Value of $a_{2008}$ in the Sequence
In summary, the sequence mentioned in "Find the Value of $a_{2008}$ in the Sequence" refers to a set of numbers arranged in a particular order, where $a_{2008}$ represents the 2008th term. The value of $a_{2008}$ can be calculated using the formula $a_n = a_1 + (n-1)d$, and if the sequence is not arithmetic, a pattern or rule must be identified. Finding the value of $a_{2008}$ is important in understanding the overall pattern of the sequence and can be done manually or with the help of a calculator or online tool if the formula is unknown.
Albert1
1,221
A sequence as follows :
$0,1,-1,2,3,-2,4,5,6,-3,7,8,9,10,-4,11,12,13,14,15,16,-5,--------$
please find :$a_{2008}=?$
Mathematics news on Phys.org
are you sure that 16 is there
I am sure that 16 is there .
if 16 is not there , then this question will be much easier
$0,1,-1,2,3,-2,4,5,6,-3,7,8,9,10,-4,11,12,13,14,15,16,-5,---------$
hint:
we have 1 number after 0
2 numbers after -1(2-3)
3 numbers after -2(4-6)
4 numbers after -3(7-10)
6 numbers after -4(11-16)
and it should have 9 numbers after -5(17-25)
can you figure out the regular pattern?
more hint:
$a_n+a_{n+2}=a_{n+3} \forall n\geq 1$
here we set $a_1=1,a_2=2,a_3=3, a_4=4,a_5=6...$
[FONT=&#26032] [/FONT]
[FONT=&#26032]n[/FONT]
[FONT=&#26032]an[/FONT]
[FONT=&#26032]0[/FONT]
[FONT=&#26032]1[/FONT]
[FONT=&#26032]2[/FONT]
[FONT=&#26032]-1[/FONT]
[FONT=&#26032]2-3[/FONT]
[FONT=&#26032]5[/FONT]
[FONT=&#26032]3[/FONT]
[FONT=&#26032]-2[/FONT]
[FONT=&#26032]4-6[/FONT]
[FONT=&#26032]9[/FONT]
[FONT=&#26032]6[/FONT]
[FONT=&#26032]-3[/FONT]
[FONT=&#26032]7-10[/FONT]
[FONT=&#26032]4[/FONT]
[FONT=&#26032]14[/FONT]
[FONT=&#26032]10[/FONT]
[FONT=&#26032]-4[/FONT]
[FONT=&#26032]11-16[/FONT]
[FONT=&#26032]21[/FONT]
[FONT=&#26032]16[/FONT]
[FONT=&#26032]-5[/FONT]
[FONT=&#26032]17-25[/FONT]
[FONT=&#26032]31[/FONT]
[FONT=&#26032]25[/FONT]
[FONT=&#26032]-6[/FONT]
[FONT=&#26032]26-38[/FONT]
[FONT=&#26032]13[/FONT]
[FONT=&#26032]45[/FONT]
[FONT=&#26032]38[/FONT]
[FONT=&#26032]-7[/FONT]
[FONT=&#26032]39-57[/FONT]
[FONT=&#26032]19[/FONT]
[FONT=&#26032]65[/FONT]
[FONT=&#26032]57[/FONT]
[FONT=&#26032]-8[/FONT]
[FONT=&#26032]58-85[/FONT]
[FONT=&#26032]28[/FONT]
[FONT=&#26032]94[/FONT]
[FONT=&#26032]85[/FONT]
[FONT=&#26032]-9[/FONT]
[FONT=&#26032]86-126[/FONT]
[FONT=&#26032]41[/FONT]
[FONT=&#26032]136[/FONT]
[FONT=&#26032]126[/FONT]
[FONT=&#26032]-10[/FONT]
[FONT=&#26032]127-186[/FONT]
[FONT=&#26032]60[/FONT]
[FONT=&#26032]197[/FONT]
[FONT=&#26032]186[/FONT]
[FONT=&#26032]-11[/FONT]
[FONT=&#26032]187-274[/FONT]
[FONT=&#26032]88[/FONT]
[FONT=&#26032]286[/FONT]
[FONT=&#26032]274[/FONT]
[FONT=&#26032]-12[/FONT]
[FONT=&#26032]275-403[/FONT]
[FONT=&#26032]129[/FONT]
[FONT=&#26032]416[/FONT]
[FONT=&#26032]403[/FONT]
[FONT=&#26032]-13[/FONT]
[FONT=&#26032]404-592[/FONT]
[FONT=&#26032]189[/FONT]
[FONT=&#26032]606[/FONT]
[FONT=&#26032]592[/FONT]
[FONT=&#26032]-14[/FONT]
[FONT=&#26032]593-869[/FONT]
[FONT=&#26032]277[/FONT]
[FONT=&#26032]884[/FONT]
[FONT=&#26032]869[/FONT]
[FONT=&#26032]-15[/FONT]
[FONT=&#26032]870-1275[/FONT]
[FONT=&#26032]406[/FONT]
[FONT=&#26032]1291[/FONT]
[FONT=&#26032]1275[/FONT]
[FONT=&#26032]-16[/FONT]
[FONT=&#26032]1276-1870[/FONT]
[FONT=&#26032]595[/FONT]
[FONT=&#26032]1887[/FONT]
[FONT=&#26032]1870[/FONT]
[FONT=&#26032]-17[/FONT]
[FONT=&#26032]1871-1990[/FONT]
[FONT=&#26032]120[/FONT]
[FONT=&#26032]2008[/FONT]
[FONT=&#26032]1990[/FONT]
FAQ: Find the Value of $a_{2008}$ in the Sequence
What is the sequence mentioned in "Find the Value of $a_{2008}$ in the Sequence"?
The sequence refers to a set of numbers arranged in a particular order, where each number is called a term. The term $a_{2008}$ represents the 2008th term in the sequence.
How is the value of $a_{2008}$ calculated in the sequence?
The value of $a_{2008}$ can be calculated using the formula $a_n = a_1 + (n-1)d$, where $a_n$ represents the nth term, $a_1$ represents the first term, and d represents the common difference between each term in the sequence.
What if the sequence is not arithmetic?
If the sequence is not arithmetic, meaning there is no constant difference between each term, then the formula $a_n = a_1 + (n-1)d$ cannot be used. Instead, you would need to look for a pattern or rule in the sequence to determine the value of $a_{2008}$.
Why is finding the value of $a_{2008}$ important in a sequence?
Knowing the value of a specific term, such as $a_{2008}$, can help in understanding the overall pattern or behavior of the sequence. It can also be used in solving more complex problems or equations that involve the sequence.
How can I find the value of $a_{2008}$ in a sequence without knowing the formula?
If you do not know the formula for the sequence, you can try to manually determine the value of $a_{2008}$ by listing out the terms and finding a pattern. You can also use a calculator or online tool to help with calculations.
