Find the value of this expression
In summary, the conversation discusses different strategies for solving the expression x^3-6x^2+6x, which is derived from the given equation x=2+2^{2/3}+2^{1/3}. Ideas like substitution and simplification are suggested, with the final solution being x^3-6x^2+6x=(x-2)^3-6x+8.
utkarshakash
If [itex]x=2+2^{2/3}+2^{1/3}[/itex], then the value of [itex]x^3-6x^2+6x[/itex] is
The very first idea that comes to my mind is to substitute the value of x in the given expression. But that gets very complicated and long as well. Any other ideas?
I don't think you can avoid this. Simplify as early and as much as possible (e.g. calculate x^2, simplify that and multiply with x to get x^3).
It doesn't look so bad...
x3 is easy since 3s cancel a lot. Then x2 isn't too bad because 2*2 +2*1 = 6 which divides by 3 easily.
It all simplifies nicely as you go along.:smile:
You can simplify the calculations a little by writting this as x(6+ x(x- 6)).
Try using [itex]x^3-6x^2+6x=(x-2)^3-6x+8[/itex]. That actually saves some work.
Thanks. It did save a lot of work.
FAQ: Find the value of this expression
What is the meaning of "Find the value of this expression"?
The phrase "Find the value of this expression" typically refers to solving a mathematical statement or equation to determine the numerical value of the given expression.
Why is it important to find the value of an expression?
Finding the value of an expression is important because it allows us to understand and analyze mathematical relationships, make accurate calculations, and apply them to real-world situations.
What are some common strategies for finding the value of an expression?
Some common strategies for finding the value of an expression include simplifying the expression, using the order of operations, substituting variables with known values, and using algebraic properties and rules.
What is the difference between evaluating and simplifying an expression?
Evaluating an expression involves replacing the variables with specific values and performing the necessary calculations to find the resulting numerical value. Simplifying an expression, on the other hand, involves using algebraic rules and properties to manipulate the expression into a simpler form without changing its value.
Can an expression have more than one value?
Yes, an expression can have more than one value depending on the values of the variables used. This is especially true for equations where the solution may have multiple solutions or for expressions with variables that can take on a range of values.
